Old 12-10-2010   #1
weapon5
Drives: NONMITS ATM
Send a message via MSN to weapon5 Send a message via Yahoo to weapon5
EVO5
hey guys if this been covered please don't flame me for it lol i used the search but me and search don't work well together. so doing a evo5 swap. you get the 2000 mirage and aside the body kit you can swap a 4g63 in directly but if you want to go awd you use the awd system on the vr4 gallant. is this the process or basic of it?
weapon5 is offline   Reply With Quote
Old 12-10-2010   #2
Re: EVO5
http://mitsustyle.com/forums/showthr...hlight=evo+iii
Old 12-10-2010   #3
Re: EVO5
ooooorrrrr you could just get one imported through Canada.
Old 12-10-2010   #4
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: EVO5
Aren't they 15 years though? The Evo V was 1998.
Originally Posted by Trogdor
Old 12-10-2010   #5
Re: EVO5
^^ You can still get older ones, I talked to a few different companies when I was trying to find an Evo 3 transmission for my Talon, and some of them still have vehicles back to 1991-92 the way it looks.
http://www.tyeeimports.com/default.asp?offset=40
Be careful with some of these companies though, I'm sure some of them are scammers, so I always called them on the phone to make sure they were who they said they were.
Old 12-10-2010   #6
Re: EVO5
I believe that the Evo V uses the same motor as the VIII. AKA not the DSM 4g63, and also most definitely not the same rear end and subframe as a GVR4.
Old 12-10-2010   #7
Re: EVO5
Correct, 4-8 all used the same motor, then the 9 is basically the same, but with MIVEC.
Old 12-10-2010   #8
weapon5
Drives: NONMITS ATM
Re: EVO5
thanks guys
Old 12-10-2010   #9
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: EVO5
this.
I'm seriously considering doing this once I get a pay raise. Well worth my investment to do so. Seeing a REAL 3,4 and 5 in Thailand was just to insane to see in real life.
I saw one build of an Evo 4 or 5 on the internet floating around somewhere but damn, there is alot of money, energy, time and knowledge put into that build and I would have only done it if I had all four of those items. The 4g63 from the DSMs definitely aren't structured the same as the 5s because as everyone else has mentioned above, it's different. The rear end from a 5 and GVR4/DSM is totally different. I'm guessing a 5 rear end would be at least similar to that of the Evo 8/9s here in the states.
ლ(ಠ益ಠლ)
Old 12-10-2010   #10
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
Re: EVO5
www.mirageforums.net They have alot of info and projects search around there.
