Old 04-07-2011   #1
backwoods
Drives: talon tsi
WTB: Mechanic to do my Timing Belt on 2GA!!
Looking for a best offer quote on someone to do my timing belt, Mines F'd!!!! and I need this done asap!!
Please include your price! If you have the timing belt assembly to do the job already please note that and include that into your price that would be great, If not lead me to a place that sells OEM cheap !
Thanks...
backwoods is offline   Reply With Quote
Old 04-07-2011   #2
twack
It was a auto get over it
twack's Avatar
Re: WTB: Mechanic to do my Timing Belt on 2GA!!
where you located, im in rochester and more then happy to do the job but if your north that might be to far
Old 04-07-2011   #3
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Did your belt break or start coming apart?
Old 04-07-2011   #4
backwoods
Drives: talon tsi
Im in the North subs, but willing to travel if the price is right....
My belt is cracked and feels loose..its the only car I have right now and its freakin' me out everytime I drive..
Thanks.
Old 04-07-2011   #5
I wouldn't be driving anywhere with a loose timing belt
Old 04-07-2011   #6
backwoods
Drives: talon tsi
quotes!!!!!!
Old 04-07-2011   #7
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
It's not hard to do. What part of the north burbs are you from?
Old 04-07-2011   #8
santa
Boost Spike
santa's Avatar
PM sent. I'm up in princeton and can do it.
Old 04-07-2011   #9
backwoods
Drives: talon tsi
Plymouth
Old 04-07-2011   #10
Brookdale mitsubishi would be your best local bet for sourcing the parts at a discount.
Old 04-08-2011   #11
backwoods
Drives: talon tsi
I have found someone to do it for 200 dollars thanks for all the help
Old 04-08-2011   #12
Shit I was going to bid $150 + parts, LOL. Good luck!
Old 04-08-2011   #13
backwoods
Drives: talon tsi
Its a friend of mine who is doing a payment plan with me because of hard times right now...
Do you or anyone have the parts on hand that I could bid on?
Old 04-08-2011   #14
I would call Brookdale Mitsubishi. Depending upon the age of the car you want a belt, tensioner, idler pulley, tensioner pulley, balance shaft belt.
It has been a few years since I've bought the parts but I would estimate the belt to be $60, Tensioner $100, Idler pulley, $20, Tensioner pulley $25, balance shaft belt $25.
I would recommend a water pump as well while you are there, should set you back another $60 if you went aftermarket.
Pulley's, tensioner's, belts, stick with OEM. Water pump you are much cheaper going aftermarket in my opinion.
Make sure your friend has the proper tools to tension it or your special deal may end up costing you big bucks when the valves get munched by the pistons.
Old 04-08-2011   #15
Did you even bother checking with our forum sponsors?
Old 04-08-2011   #16
backwoods
Drives: talon tsi
I know modern has a kit for 160$...Probably my best bet atm..
I tend to stay away from Crookdale Mitsubishi because they want 14$ a piece on bolts, I think 1,500$ it was for a brand new FMIC core on a Evo also...just so pricey IMO
Old 04-08-2011   #17
I am sure Map, Primo, or DB could put together a wicked package price.
Old 04-08-2011   #18
$219 if you add the BS belt and pulley (unless your friend is pulling the oil pump and eliminating that while he is there). Still A++ pricing from MAP.
Old 04-08-2011   #19
backwoods
Drives: talon tsi
Isn't the BS eliminator kit really cheap? Is it practical to eliminate that while where doin the timing belt
Old 04-08-2011   #20
No its not that easy. I would buy the balance shaft stuff, most of the time this is what breaks first and takes out the timing belt.
