Old 10-06-2011   #1
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
2 year build complete, dyno day set!!!
I am finally done with my build and just set up my dyno day at DBperformance in Roger,MN. I am going for 500-550 awhp and is still my DD. I would be lying if I said I wasn't nervous but I hope she doesn't blow up on me. I am bleeding the brakes and burping the power steering this weekend and she hits the dyno 10/14/11. Anyone have anything I should recheck before going there?
Here are some pictures of the finished product:
ID:	12030   Click image for larger version
If you can't afford to buy an EVO, might as well beat an EVO
Boomdeeze is offline   Reply With Quote
Old 10-06-2011   #2
Re: 2 year build complete, dyno day set!!!
Check/fix any boost leaks.
Shane also wrote up a nice checklist that is good to go through.
http://dbperformancetuning.com/cat/p...ID=24&CDpath=8
Old 10-06-2011   #3
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I read through his checklist and is a great checklist. Can't seem to get the feed line fitting on the turbo to seal but it should be taken care of before next Friday. I am going to do about 10 BLT's between now and next Friday to ensure it is sealed up.
Old 10-06-2011   #4
Use hairspray on the inside of the couplers/outside of pipes, seals them up, makes them hold good. What's ur setup?
Old 10-06-2011   #5
chris02rex
chris02rex's Avatar
Drives: 02 WRX/STI, 91 Tsi AWD, 07 Silverado
I cant wait to see this thing rip in alex next weekend or whenever you come up here.
chris02rex is offline   Reply With Quote
Old 10-06-2011   #6
99gsxjoel
Drives: 1999 GSX
Nice man looks sick.
99gsxjoel is offline   Reply With Quote
Old 10-06-2011   #7
Check your power estimates at the door! 500 on this dyno on AWD is not impossible but I have seen a *lot* of cars come and go on that dyno and not get anywhere close. If you make 400, be happy, be very very happy! Stuff happens. Don't give up. If you run into a limitation, learn from it and come back once you have issues/combo sorted out.
Awesome list! Take the time to go through it, well worth it and great advice.
Old 10-06-2011   #8
GOod luck dude, I promise i'll look at that fitting tomorrow for you.
Old 10-06-2011   #9
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Thanks for all the advice guys, I will do all that this weekend. And I ended up buying the fitting from STM along with a coupler I will need to change out before the dyno.
I have a borg s259 ett with a custom twin scroll t4 housing, DP t4 manifold,turbosmart 45mm WG, v-band exhaust, stock 6 bolt rods with evo 9 pistons, JMF race intake mani, VR speed FMIC, built head, a lot of bolt ons
Old 10-07-2011   #10
Isn't that kind of a small turbo for a t4 housing? Or is the fact it's twin scroll gonna make it not matter? And your biggest hurdle is fuel system, having enough pump to keep up with the demand of 500awhp on a dyno dynamics.
Old 10-07-2011   #11
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I have a walbro 255 intank and an Aeromotive Tsunami inline pump. The exhaust housing is an .84 AR housing so shouldn't have any problem spooling.
Old 10-07-2011   #12
Nice setup and turbo choice. I'd bet you could come close to 500hp if you are running 35+psi with that turbo.
Old 10-08-2011   #13
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
I don't want to go much past 30 maybe Max out at 32. I guess we will find out Friday, I will post up the outcome.
Old 10-08-2011   #14
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
awesome glad to see your finally done for now!
Old 10-09-2011   #15
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Make sure your good to go on ignition. I hit 463awhp on db's dyno on 27psi and could go no further because I was breaking up so bad... I wanted 500 on that dyno and can hit that mark but fell short due to 1 little problem. My point is, don't be dissapointed if you fall a little shy of your power mark. Like they said "If you make 400, be happy, be very very happy!"
Good luck and I hope you make you goals.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 10-09-2011   #16
Just as a reference, I was running an S362 (a hair larger than yours) and made on that same dyno:
480 @ 28psi
515 @ 32psi
541 @ 35psi
My setup sounded similar to yours, except slightly larger turbo, and mine was crammed into a T3 housing.
Old 10-09-2011   #17
blackawdtsi
Drives: 2G DSM
FWIW, it took me 29psi on a T4 .68 T67 to make 512. Good luck.
Old 10-09-2011   #18
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
Thanks for all the input guys, I know I will be very happy if she makes it through the dyno session without something going wrong.
Old 10-09-2011   #19
Boomdeeze
Boomdeeze's Avatar
Drives: 97 GSX
DO you guys think I should wait until next spring to get my car tuned? I heard that e85 is actually down to e70 already.
Old 10-09-2011   #20
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
iirc Shane can tune it fine and when the good stuff comes around your tune will be safe to turn up boost. Also i dont think we get e85 till May. Its all up to you.
