Old 06-02-2011   #1
v8klla
v8klla's Avatar
MAP Turbochargers Official Release / Beta Testing Program
MAP EF2 Turbocharger $1695 MSRP
Introducing the MAP EF2 turbocharger, the smallest of our three variations. Don't let its size fool you though, this bad boy retains incredible spool characteristics and packs a significant punch up to 450whp. The EF2 is a great choice for those looking to retain some "stomp and go" in their daily driver or a corner-ripping solution for the road course or autocross.
This turbo features upgraded thrust components with dual oiling ports for improved lubrication along with a brand new, super efficient compressor blade profile that we are confident will outperform any wheel with the same inducer/exducer dimensions. What more could you possibly be after? Well if it's more power, check out the MAP EF3!
MAP EF3 Turbocharger $1999 MSRP
Introducing the MAP EF3, our attempt at the proverbial "best of both worlds" turbocharger. It's capable of making 100whp more than the EF2 (more than enough to add a window to your stock block should you so choose) while still retaining manageable spool characteristics for your daily driver or weekend warrior.
This turbo features upgraded thrust components with dual oiling ports for improved lubrication, upgraded thrust bearing material, and a brand new, super efficient compressor blade profile that we are confident will outperform any wheel with the same inducer/exducer dimensions. What more could you possibly be after? Well if it's more power, check out the MAP EF4!
MAP EF4 Turbocharger $1999 MSRP
Introducing the MAP EF4, one of the biggest and baddest turbochargers ever squeezed into a stock frame housing. Capable of 650whp this turbocharger offers incredible spool characteristics in comparison to similarly sized T3 turbochargers due to the twin scroll turbine housing, not to mention you are able to reuse your exhaust manifold / O2 housing / downpipe making this the most affordable route to 650whp as well!
This turbo features upgraded thrust components with dual oiling ports for improved lubrication, upgraded thrust bearing material, and a brand new, super efficient compressor blade profile that we are confident will outperform any wheel with the same inducer/exducer dimensions. If you want more than 650whp then you're going to have to ditch the stock frame mindset. Be sure to check out the MAP T3 Turbo Kit (Coming Soon)!
Frequently Asked Questions
Can you provide compressor maps or flow rates?
We are working on obtaining flow rates and should have that information in 1-2 weeks. Compressor maps are much harder to obtain, but we will be exploring the possibility further.
What can I expect the EFX turbocharger to make at XXpsi and when will it hit peak boost?
Although we have done extensive testing in house the vehicle we utilized is not an ideal platform to adequately answer these questions (2.4L, Stage 5 Cylinder Head, GSC S3 Cams, 5" Intercooler, etc.). We developed this beta testing program along with the 20% discount incentive with the goal of obtaining real world feedback from several different sources to compile a database of results specifically to address such questions in the near future.
How does your EFX turbocharger compare to an (Insert competitor here)?
We are confident that our turbochargers will outperform anything on the market with similar inducer/exducer dimensions. With that being said we have not yet been able to directly compare our turbos against that of the competition. We currently have some in house testing in the works, and we fully expect comparisons to be made from the beta testing group as well.
Do you offer these in ball bearing?
At this point in time they are only offered in journal bearing configurations. Rest assured we are working diligently to develop a reliable ball bearing solution, but we are still a ways out.
Beta Testing Program & Incentives
Our initial batch of approximately 75 turbochargers will be distributed via our Beta Testing Program. Essentially, we will be passing along a 20% discount to early adopters in return for their feedback in regards to spool characteristics, power output, etc so that we can compile a database of information and real world results for each of our turbo variations. If you would like more information in regards to our Beta Testing Program please contact your favorite MAP sales rep today as quantities are limited!
Designed, machined, assembled, and balanced at MAP in the good 'ole USA!
http://www.youtube.com/watch?v=XlBd2bOSNCk&hd=1
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-02-2011   #3
v8klla
v8klla's Avatar
Re: MAP Turbochargers Official Release / Beta Testing Program
It is a modified OEM journal bearing design.
P: 763-545-3800
Old 06-02-2011   #4
Let me know when you want some DSM versions tested.
Old 06-03-2011   #5
BluDevl
Drives: 2005 S40 T5 AWD Weekender: '92 Stealth TT
Or if you want a 3/S version tested!
BluDevl is offline   Reply With Quote
Old 10-19-2011   #6
My MAP EF2X turbo review: http://www.mitsustyle.com/forums/showthread.php?t=30627
