Old 12-28-2011   #1
chris02rex
chris02rex's Avatar
Drives: 02 WRX/STI, 91 Tsi AWD, 07 Silverado
Need Help ASAP Please
Hey guys i just finished putting my motor back together and swapping to awd. I bought the car with a rod through the block and have never driven it. We went to start it up and the pump does not turn on. I have swapped relays and still cant get the pump to turn on. When we hook up the power to the test port in the engine the pump will turn on. I cant figure this out and leave to school on saturday 10 hours away from home. any help would be greatly appreciated. You can also text me at 3204919251. Thanks a ton in advance.
chris02rex is offline   Reply With Quote
Old 12-28-2011   #2
Re: Need Help ASAP Please
NOT A PROJECT! Moving to tech section.
Old 12-28-2011   #3
chris02rex
chris02rex's Avatar
Terribly sorry. Posted this in a hurry. Also just an update on it i do not have any power to the relay. Any ideas?
Old 12-28-2011   #4
what pump you running? rewire the ground wire to the chassis?
Old 12-28-2011   #5
chris02rex
chris02rex's Avatar
I did jumper the ground wire from the pump to the chassis. its a wally 255. If i use the test connector under the engine bay the pump will turn on but no power at the relay at any of the four terminals.
