Old 01-04-2012   #1
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
ecmlink v3 and wideband
I have a 1g basically stock, im going install V3. I just want to make sure im correct about this... I can replace the stock o2 sensor with a wideband sensor without the need to weld an additional bung because ecmlink v3 has the narrowband simulation function eliminating the need for the stock o2 sensor. right? just put the wideband in the stock o2 bung?
Old 01-04-2012   #2
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: ecmlink v3 and wideband
Yes you can just use a wideband.
11.35 @ 120mph
Old 01-04-2012   #3
dsmghost
dsmghost's Avatar
Ok thanks for the confirmation
Old 01-04-2012   #4
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Correct me if I'm wrong, but don't most wideband sensors burn up quickly when they're in place of the o2 sensor? I had always thought they needed to be certain distance from the discharge on the turbine outlet.
Old 01-05-2012   #5
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
^ agreed, plus for it to read most accurately closer to your downpipe mid section ive always read and had most success with.
Old 03-02-2012   #6
4*G*6*3
Drives: 1ga eclipse gsx awd, 75 mercedes 450sl
hey aj, its ivan.
i'm pretty sure it should be 18-32" maybe more away from the exhaust housing..
hows it going with the new shell?
4*G*6*3 is offline   Reply With Quote
Old 03-02-2012   #7
I haven't had problems with mine in the stock location. Plus I consider sensors a yearly replacement item anyway due to their low cost these days. They used to be crazy expensive.
Old 03-07-2012   #8
18" - 24" is optimal.
