Old 04-02-2013   #1
Custom Braided lines
Anyone know of any local hydraulic shops or anything that can make custom SS Braided lines? Looking to get a clutch line made.
Or on another note, is it OK to just run say a standard -3 or -4 braided line, and some AN fittings for something like that (kind of like a fuel line)? Or is there too much pressure in a clutch system for those kinds of fittings?
Old 04-02-2013   #2
Re: Custom Braided lines
Not local, but they'll custom make you lines: http://www.techna-fit.com/
Old 04-02-2013   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Its fine to run the braided line but you're better off with -3AN. I've seen problems with -4AN and its pretty "spongy". A lot more fluid to compress and its in a rubber hose now. Makes the pedal softer with a SS braided line as well. Even going to a -3AN will soften the pedal some vs steel line.
Originally Posted by shoutbox
Old 04-02-2013   #4
Check with local diesel repair shops. I had one do some for me quite a while back and I can't remember who it was.
Old 04-02-2013   #5
I think you have the wrong idea, I'm not replacing all the hard line. The way my car is stock is:
Master Cyl | Hard Line | Rubber Line | Additional Random Loopy Bent Excessive Lengths Of Hard Line | Slave Cyl
That last section of excessive hard line doesn't line up with the new 350z clutch slave. And no idea why it's even there because the rubber line could reach the slave if they wanted it to. So anyhow I want a small length (12") of braided line to replace the Rubber and Additional Hard portion so it will become:
Master Cyl | Hard Line | Braided Line | Slave Cyl
Anyhow, I ordered a 240sx line which should hopefully do the trick.
Old 04-02-2013   #6
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Perteq best most friendly and closest to us in the city's Ive gotten tons of stuff done by them...might not be the cheapest always but generally its done on the spot while your watching or within a few days Look em up!
Old 04-02-2013   #7
http://www.perteq.com/
They don't look local?
Old 04-02-2013   #8
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
I apologize, i cant spell sometimes... with this android phone...its spelled Pirtek again my bad ha
http://www.pirtekusa.com/fwp/plymouth/
Old 04-02-2013   #9
They are great to work with. I buy all my an fittings and lines from them. They have the best prices. They beat anyone and don't sell china crap lines or fittings
Old 04-03-2013   #10
They are right on uni just east of 280 i believe.
Old 04-03-2013   #11
A friend of mine used Pirtek for the Scorpio brake lines, he had nothing but good things to say.
Old 04-03-2013   #12
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
There also is one located in the plymouth area so they are located sort of between both worlds. . . .as far as city locations ...might be a drive sometimes but itll be worth it. Especially if you know what youre talking about and need you can call in ahead of time.
