Old 06-24-2013   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
headgasket install composite vs multi layer metal
So I put the motor back together fired her up and before I knew it.
Coolant in the oil
So I re-torque the arps, and now I'm getting air bubbles in the oil
I didnt deck the head or block before installing mutli layer hg.
So I went and bought a composite gasket going to swap out.
How much psi can a composite handle ? Or is it more about cylinder pressure and detonation?
Anyone wanna give a hand on install
M1L3S is offline   Reply With Quote
Old 06-24-2013   #2
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: headgasket install composite vs multi layer metal
from what i read the hold will have alot to do with the studs. i read people into the twenties for sure.
Old 06-24-2013   #3
Composites are good if your decks aren't perfectly flat, they make up for imperfections. Without a lot of detonation, they can actually handle a lot.
Old 06-24-2013   #4
M1L3S
M1L3S's Avatar
Drives: 99Gst
Would they be able to handle 25-30psi ?
Old 06-24-2013   #5
I ran 26-28psi on my 6 bolt with an FP red a few years ago, never blew the composite headgasket. Had standard ARP's that had been torqued a couple times.
Old 06-24-2013   #6
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I ran 30psi on a composite all last summer. When I pulled the head it still looked good. It's all in the tune and the studs if the gasket will hold.
11.35 @ 120mph
Old 06-24-2013   #7
^X2.
Old 06-24-2013   #8
I always ran a composite with either standard ARP's or L19's. 35psi with my 62mm was starting to finally give me troubles after awhile, would have moved onto an MLS if I would have kept the car.
Old 06-24-2013   #9
I used to run 32psi on standard ARP's with a composite. it is a nice fuse to have, I would rather blow a HG than have something else go bad.
