Old 06-07-2013   #1
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Holset, FMIC, 6 bolt block
Alright I have a few things that need to go,
First off is a Holset big H1C, fresh rebuild so zero shaft play and spins perfect, will let go for $100 because I don't have a turbine housing for it, sold my BEP housing separate.
Next is a FMIC, 2.5" in and out, about 12" tall with a 18" wide 3" thick core, leaks a little not that bad, could be fixed pretty easy. Pipes are a little banged up also. $40 takes it.
Block sold
If interested PM me
punxnotdead185 is offline   Reply With Quote
Old 06-07-2013   #2
enasnitsi
Drives: 1993 Talon Awd
Re: Holset, FMIC, 6 bolt block
Anyone able to bring the block and crank to proving grounds? Can't make it to the cities anytime soon.
enasnitsi is offline   Reply With Quote
Old 06-17-2013   #3
punxnotdead185
Still have this stuff, make me an offer, turbo works with the HX35 BEP housings and is only 4lb/min less flow than an 8 blade HX, 54mm vs 56mm
