Old 10-05-2013   #1
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Bad ball joint like symptoms
Ok guys so the other day I had my front end jacked up and checked for ball joint movement. I noticed that when I put my hands on the top and bottom of the tire and moved it in and out that there was a good amount of play. So today I replaced the balljoint. Tires still moves in and out when I wiggle it. Replaced the tie rod ends before my alignment about a 1000 miles ago so those are good.
Any ideas?
Thanks, Mark
BW8776, e-85
Old 10-05-2013   #2
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Bad ball joint like symptoms
Wheel bearing.
Old 10-05-2013   #3
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
^+1
2006 WW IX RS 396/404 - SOLD
Old 10-06-2013   #4
twack
It was a auto get over it
twack's Avatar
exact same thing happened to me.....wheel bearing
Old 10-06-2013   #5
mdost03
Sonic Champion!
Drives: VA STI
Wheel Bearing for sure.
Old 10-06-2013   #6
I just had that same thing, although there was very little play and it didn't have the usual howl, just a light popping sound around corners. Wheel bearings have some strange symptoms sometimes.
Old 10-06-2013   #7
mark4g63t
mark4g63t's Avatar
Could be the wheel bearing but that was also replaced a couple months ago when the new hub and axle went in. Will get another and try it out since it's got a lifetime warranty.
Thanks guys
BW8776, e-85
Old 10-06-2013   #8
mark4g63t
mark4g63t's Avatar
Well apparently only had a year warranty and it ended last month oh well
BW8776, e-85
Old 10-06-2013   #9
polishmafia
Where are you buying your parts from? Are you getting them all from the same place? Go to the store, play nice and ask them if they will cover it, or at least part of it.
Old 10-06-2013   #10
mark4g63t
mark4g63t's Avatar
yea from the same oreillys. Willing to give it a try.
BW8776, e-85
Old 10-06-2013   #11
mdost03
Sonic Champion!
Drives: VA STI
I bought an OReilly wheel bearing and it was defective out of the box (howling when driving). Returned it and got a Napa one and was way better quality for less money.
Old 10-06-2013   #12
twack
twack's Avatar
^this
and never autozone
Old 10-06-2013   #13
b00sted_spyder
You can never go wrong with OEM. Another way to check for wheel bearing is to jack up the car and have someone drive the car in the air. Feel the springs. There should be no vibration. If there is, that wheel bearing is on it's way out.
Old 10-07-2013   #14
mark4g63t
mark4g63t's Avatar
New symptom. After putting in the ball joint on my driver side the car pulls right. Only during wot. Crazy hard,
BW8776, e-85
Old 10-07-2013   #15
polishmafia
You should get the alignment checked after you put a ball joint in. If the passenger is older than the new driver side, it can be weakened and cause alignment issues.
Old 10-07-2013   #16
mark4g63t
mark4g63t's Avatar
yea i'm getting it realigned sometime this week either at class or under my warranty from the last alignment as I can tell the steering wheel is off center again. But besides that it pulls wicked hard to the right.
BW8776, e-85
