05-25-2014
Drives: 2003 evo 8
Iowa: Leftover oem/aftermarket parts! evo 8-10/dsm:AMS, BR, Power Stop, HAWK, GREDDY!
Hi evo 8-10/dsm/talon/eclispe owners! Here is the left over oem/aftermarket parts from my build! I paid a lot of money through the course of this project; my loss is your gain!
- Parts are ready to ship after my paypal has cleared usually same day,
pm for paypal address after agreement to purchase part.
- PRICES DO NOT INCLUDE PAYPAL FEES OR SHIPPING and I will only charge actual shipping cost with insurance via usps, Fedex, or UPS.
Please be serious upon purchase before asking for shipping quotes!
- If a price is out of line with the market cost, do not be afraid to make an offer; however I have done the research and believe these are accurate evolutionm going rate prices. The worst thing is that I would say no!
Please contact Scott via pm or cell #:
http://www.hidetext.net/hide/mMaqGfFqy9.gif
Please see my local craigslist for evo or Honda parts:
http://desmoines.craigslist.org/pts/4716878775.html
Flickr for all pictures not displayed in post:
https://www.flickr.com/photos/114062...7644405339718/
Aftermarket evo parts: 3k or less miles unless noted otherwise:
- Fidanza cam gear (black) (2K) - $100
- AMS shifter base bushing kit BNIB - $40
- Hawk front pads (2k) (1 pad has scrap in it, not sure if this is issue or not) - $75
- Hawk rear pads (2k) - $75
- Precision Turbo PTE6262 5 bolt turbine housing Tirado Custom Coatings gold ceramic coated BNIB (TCC does perfect work, but 3 month wait) - $150
- FIC fuel injector seals (Used 2K from 2150s) - $20
- dimple oil drain plug (1 oil change) - $30
- APR GTC-200 carbon fiber side plate ( AA-100048 ) BNIB - $45
Universal evo parts:
- ALTEC PRODUCTS Show-N-Go motorized front license plate w/ remote BNIB - $100
- Rockford Fosgate positive battery terminal (gold 'R' shape) BNIB - $30
- Ichibahn valve stem caps (yellow) BNIB - $8
- Pilot led side marker lights BNIB - $20
- Lightning Audio 1 farad capacitor BNIB - $50
- 1/2" 20 x 3/4 oil drain plug BNIB - $10
- -8AN braided stainless line (w/new straight fitting (black) not yet installed) - $30
- Hose Techniques silicone 2.5" 90 degree coupler (red) BNIB - $20
- Silicone 4" to 3" reducer coupler (black) - $5
- NASCAR carbon fiber 4" to 3" reducer - $20
- APC Super White 1157 bulbs BNIB - $5
- Spider lite led bulbs (red) 7443 BNIB - $20
oem evo 8/9 parts: 42K or 52K miles unless noted otherwise:
- evo 8/9 throttle body (52k no sensors) - $75
- evo 8/9 radiator (52k) - $125
- 4 evo 8/9 oil cap - $10
- evo 9 cams (42k) - $75
- evo 8/9 oil pump (42k) - $75
- evo 8/9 front strut bar - $ Need to figure out price and add picture!
- evo 8 carbon fiber oem wing (Red, near perfect clear coat) - $275
- evo 8 front bumper duct - $20
- evo 8 front bumper oil cooler duct - $25
- evo 8 front bumper long metal bracket - $25
- evo 8/9 front crash beam brackets (RR) - $25
- evo 8/9 front mount bracket - $15
- evo 8 bumper Styrofoam LH - $10
- evo 8 bumper Styrofoam RH - $10
- evo 8 rear bumper metal bracket - $10
- evo 8/9 hood release latch - $15
- evo 8/9 radiator hose (52k still good) - $5
- evo 8/9 radiator brackets (No rubber) - $5
- evo 8 engine harness (52k) (SOLD AS IS: Was perfect harness, but had to cut some wires due to evolutionm vendor sold undisclosed damaged evo 9 harness ): - $200
- evo 8 chassis/headlight harness - $130
- evo 8 dash harness (Some wires patched into for alarm) - $130
- evo 8 transmission wire harness (52k) - $50
- 2 evo 9 chassis/headlight harness (SOLD AS IS: evolutionm vendor sold undisclosed damage/modified harness) - $100 each
- evo 9 dash harness (SOLD AS IS: same above evolutionm vendor) - $100
- 3 evo 8/9 horn - $15 each
- evo 8/9 flywheel (42k) - $75
- evo 8/9 O2 housing with spring bolts (42k) - $60
- evo 8/9 balance shaft (52k) - $20
- evo 8/9 cd player (25k) - $25
- evo 8/9 front brake lines (52k) - $20
- evo 8/9 rear brake lines (52k) - $20
- evo 8/9 fuel pressure solenoid (52k) - $30
- evo 8/9 undertray (center panel only) - $25
- evo 8/9 extended fuel feed line - $10
- evo 8/9 EGR valve (42k) - $25
- evo 9 oil pressure switch (42K) - $10
- evo 8 clutch fork and springs (52k) - $30
- evo 8 firewall relay (52k) - $15
- evo 8 turbo coolant lines - $25
- evo 8/9 vacuum bracket (valve cover) - $5
- evo 8/9 vacuum bracket - $5
- 2 evo 8/9 intake manifold bracket - $5
Sold- evo 8 spark plug cover - $25
- RALLIART shoulder pads (red) - $10
- evo 8/9 turbo exhaust manifold (42k) - $80
- evo 8/9 turbo exhaust manifold heat shield w/ bolts - $10
- EXEDY Twin HD (Needs rebuild, 35K) - $600
- splinedrive closed end lug nuts (M12 x 1.5 chrome/some rust from winters) - $10
- evo 8/9 crank (42k) - $350
- Yonaka Racing radiator w/ dual slim fans BNIB - $300
- evo X Beatrush front license plate bracket BNIB - $50
- gReddy Profec b spec 2 electronic boost controller - $200
- Buschur Racing Rear Side Diff Supports (solid/race) BNIB - $330
- evo 8 upper timing belt cover - $35
- Powerslot front/rear slotted rotors (cryotreated) (2k)- $350
- Vibrant MAF adapter - $20
- evo 8 alternator brackets - $25
- AMS motor mounts (side/5 speed transmission) (red) (2K) - $200
- Perrin 4.5" universal cone filter (red) BNIB - $40
- evo 8/9 trunk (red) - $250
- evo 8/9 EGR system (52k) - $50
- MAP Billet Cam Angle Sensor Cover (green top, 1g DSM & 2g 6 Bolt Swaps) BNIB - $45
Universal
 [/url]
evo 8/9 most with either (42K) or (52K)
evo 8 engine harness (52k) (SOLD AS IS: Was perfect harness, but had to cut some wires due to evolutionm vendor sold undisclosed damaged evo 9 harness ); - $200
evo 9 dash harness (SOLD AS IS: evolutionm vendor sold undisclosed damage/modified harness) - $100[/B]
05-31-2014
Drives: 2003 evo 8
Re: Iowa: Leftover oem/aftermarket parts! evo 8-10/dsm:AMS, BR, Power Stop, HAWK, GRE
Bump!
05-31-2014
Drives: 2003 evo 8
Bump!
The following parts sold:
momo & RALLIART shoulder seatbelt pads sold!
06-04-2014
Drives: 2003 evo 8
Bump, the following parts are sold:
evo 8 (35k) fly wheel
evo 9 turbo exhaust manifold
Looking for more buyers!
06-19-2014
Drives: 2003 evo 8
Bump!
The following parts sold!
- evo 8/9 exhaust manifold shield with bolts
- EXEDY twin HD clutch (needs rebuild)
- evo 8/9 lug nuts
I know someone from this forum needs evo 8-10/dsm parts
07-02-2014
Drives: 2003 evo 8
Bump, all pms returned!
evo 8/9 crankshaft (42k)
evo X Beatrush front license plate frame
& Yonaka Racing radiator w shroud and dual slim fans BNIB sold!
07-13-2014
Drives: 2003 evo 8
Bump, gReddy Profec B Spec II sold!
Thank you to all those that have bought parts, but many parts left, need more buyers!
08-02-2014
Drives: 2003 evo 8
Bump!
BR rear diff side mounts and evo 8 upper timing cover sold!
08-09-2014
Drives: 2003 evo 8
Bump!
Powerslot cryotreated slotted (front/rear) rotors (2k) sold!
08-23-2014
Drives: 2003 evo 8
Bump!
10-13-2014
Drives: 2003 evo 8
Bump!
Vibrant MAF adapter sold!
10-25-2014
Drives: 2003 evo 8
Bump!
AMS engine mounts and Perrin air filter sold!
10-30-2014
Drives: 2003 evo 8
Bump for more buyers!
evo 8/9 trunk (red) - $250 sold!
12-19-2014
Drives: 2003 evo 8
Bump!
12-27-2014
Drives: 2003 evo 8
Bump, thank you for all those that have bought parts.
Post updated, who else needs parts?
evo 8/9 EGR system (52k) sold!
Thanks!
01-03-2015
Drives: 2003 evo 8
Bump!
MAP Billet Cam Angle Sensor Cover (green top, 1g DSM & 2g 6 Bolt Swaps) BNIB sold!
01-06-2015
Drives: 2003 evo 8
Bump, post updated!
01-11-2015
Drives: 2003 evo 8
Evening bump!
oem evo 9 cams (42k) sold
01-16-2015
Drives: 2003 evo 8
Bump! - evo 9 cams (42k) - $75
- 3 evo 8/9 oil caps - $10 each
Thank you to everyone that have purchased from me!
