Old 01-09-2016   #1
93gtpeater
Drives: cbr 1000rr repsol
Pauls bikes
I see some bike threads on here so I figure I will start one.
07 gsxr 1000 that iam putting back to stock and selling it come spring.
03 busa that iam building into a drag bike. Plans for this season are swingarm 12 inch over, 2 inch flat oil pan, and side winder exhaust. I would also like to get the bike lower.
03 turbo busa. Bike has a stage 1 turbo kit boosting 5 pounds. Plans are to get the throttle body seals fixed and fix the oil return line. I might turn up the boost after I fix the 2 things. I should be able to go up to 8 pounds on pump gas. I plan on keeping it a pump gas bike.
02 honda cr 250 2 smoke. Plans for this beast are new tires and strip the bike down and fix anything it needs before I trail ride it this summer. Bike has been to hell and back. Never skipped a beat even after it hydro locked a couple years ago.
ID:	15672   Click image for larger version
ID:	15673   Click image for larger version
Old 01-09-2016   #2
Re: Pauls bikes
Sooo many bikes! It'd be hard to keep up moding all dem sum bitches.
Should be a good thread!
Old 01-10-2016   #3
Re: Pauls bikes
Badass
Old 01-12-2016   #4
93gtpeater
Re: Pauls bikes
Here's a time slip from last at bir. My best time on the bike running mr12 race gas. This summer I hope to run 9.3x on pump gas with the bike longer and lower.
Old 01-13-2016   #5
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Question Re: Pauls bikes
Which bike?
Old 01-13-2016   #6
93gtpeater
Re: Pauls bikes
That's one the white busa. I have not taken the turbo bike to the track yet. I might take the turbo bike to the track this spring and see if I can get a 9 out of it. It's stock wheel base, stock gearing, and stock ride height. It loves to wheelie 1st and 2nd gear.
Old 01-13-2016   #7
Re: Pauls bikes
I didn't realize white folks actually rode Hyabusas
Old 01-22-2016   #8
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Re: Pauls bikes
Old 01-22-2016   #9
93gtpeater
Re: Pauls bikes
Hahahaha priceless
Hopefully the gsxr will be sold by spring. Then I will just ride the turbo busa till it sells. Hopefully sell close to fall so I can pick up a cheap cruiser. Gf told me I should buy a cruiser. So that's the plan. Cruiser, drag bike, and some dirt bikes. I don't know if I will buy another street bike. I can always ride the drag on the street and push my lucky with the police.
Old 01-22-2016   #10
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Re: Pauls bikes
Hahahaha priceless
YESSS!! Come to the old side! Cruiser is my main mode of transportation in the summer now. Plus we can do couples thangs in the summer with brizzle and his wife as well.
Old 01-22-2016   #11
93gtpeater
Re: Pauls bikes
Lol sounds like a plan.
Old 01-22-2016   #12
Re: Pauls bikes
You guys should start a bike gang
Old 01-22-2016   #13
Re: Pauls bikes
I thought 'style was a gang?
Old 01-23-2016   #14
Re: Pauls bikes
ugh, i never make the cut. :cry:
Old 01-23-2016   #15
93gtpeater
Re: Pauls bikes
Worked in the garage today and finish exhaust swap on the gsxr. I have somebody that sounds interested in buy the gsxr soon. I worked on the busa a little today too. I bought a chrome moly swingarm that's 12 inches longer then stock. It should be a little lighter then the stock swingarm. Bike weighs 470 pounds right now. I hope after the swingarm and some other stuff I plan on doing I can get the bike down to 450 pounds. I also plan on painting the bike this winter. Iam thinking blue or red right now. Here's what the bike looks like now with stock swingarm with 6 inch extensions and it plastic dipped white.
ID:	15706   Click image for larger version
Old 01-27-2016   #16
93gtpeater
Re: Pauls bikes
Installed my new swingarm tonight. Pretty happy with how easy it was to install the new arm and how it looks installed. Now I need to figure how long of a chain I need and figure out how to use my rear brake or just ditch the rear brake. Getting close one part at a time.
ID:	15713   Click image for larger version
ID:	15714   Click image for larger version
Old 01-27-2016   #17
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Re: Pauls bikes
Your 60-0 times would be a lot better with a rear brake. I say keep it especially if that thing is going that fast in the 1/4.
Old 01-28-2016   #18
Re: Pauls bikes
That swingarm looks good on there for sure!
Fuck a back brake, I'd have my off if I didn't have to modify the bracket so I can use the speedo sensnsor
Old 01-28-2016   #19
93gtpeater
Re: Pauls bikes
Well I guess I will order a spacer so I can delete the rear brake.
Old 02-04-2016   #20
93gtpeater
Re: Pauls bikes
So I took all the plasti dip off the bike and started to prep it for paint. So far I have painted the tail section on the bike. Iam very happy on how good the tail section turned out for a rush job. I will take as many pics possible.
One picture is it all primed, 2nd picture is it painted, 3rd is it all wet sanded and buffed
ID:	15737   Click image for larger version
ID:	15738   Click image for larger version
