Old 11-11-2003   #1
Mike_91_TSi
Guest
Tournaments Won: 6
Posts: n/a
The metal tab that attaches that to the glass has detached from the damn glass. It looks like it was either glued or soldered on. Is there anyway to reattach this?
Thanks!
Mike Ert
91 TSi
Old 11-11-2003   #2
It is actually a type of solder. It is pretty similar to silver solder. I would give that a try.
Old 11-11-2003   #3
john
Business as usual
john's Avatar
That happened to mine a while ago. I soldered it back on. It took me a while though. I used regular electrical solder. Had trouble getting it to stick. Damn thing would always come loose after I let go. It would save a lot of time if you had someone help you. Maybe find a better solder also (silver solder). I have only heard of using silver solder on radiators though.
97 Viper GTS
Old 11-11-2003   #4
LightningGSX
Hellbound
You can use conductive epoxy too.
-Nulli Secundus-
Old 11-11-2003   #5
Raptor
ConArtist
Raptor's Avatar
If someone is using silver solder on a radiator, they have a larger bankroll than me. Silver solder is actually made with silver and is much more expensive than regular solder. Most people use regular lead/tin solder for radiators. With the back window, There are safer methods than trying to connect it with a soldering iron. check this site out for an easier fix.
defroster repair
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 11-11-2003   #6
john
Business as usual
john's Avatar
wish I would have glued it. Soldering that was a bitch doing it alone (holding tab, solder, and iorn).
97 Viper GTS
Old 11-12-2003   #7
Mike_91_TSi
Guest
Tournaments Won: 6
Posts: n/a
Well damn. While the last 2 posts came in I was in the garage. I did get it reattached with solder. I did also have trouble making it stick until i juiced it up with some flux(sp). Then it was all good. If this fails again I will try the glue.
Old 11-13-2003   #8
john
Business as usual
john's Avatar
HA HA HA HA. Same thing happened me. I didn't think of using flux when I did it though :headache: . Atleast it is back on there. Mine has held for probly 8 months so far.
97 Viper GTS
Old 11-13-2003   #9
Flux is a necessity when soldering. It allows the solder to flow better, adheres better to what you're soldering and it hardens better than if you didn't use it.
Old 11-13-2003   #10
john
Business as usual
john's Avatar
Yeah, I always end up using new wires so I never solder. They aren'y dirty at all.
97 Viper GTS
