09-09-2004
Drives: '93 mirage es - evoIII
i was looking at getting the BR manual boost controller from buschur racing or do you suggest go with another one.. if so. what are a few other boost controllers ya'll would suggest getting, thanks.......
1993 Mitsubishi Mirage ES - soon to be EVOIII...
09-10-2004
A manual boost controller is a manual boost controller. None are more powerful than another. I prefer the Hallman for ease of use and awesome customer service.
09-10-2004
is a mbc suposed to bleed air before it hits full boost? mine will start leaking around 14psi and up..
-E
Joe P. $40 I believe from www.boostcontroller.com
That was my mindset as well when I bought 2 different style Ebay MBC's. Whatta waste of money on my part. Never again. Get something made by someone reputable.
09-10-2004
Also make sure you get a ball/spring design, bleeder-valves are bad.
Guest
HKS EVC IV i love it
09-10-2004
okay, thanks for the info. guys.....
09-10-2004
Hey, I actually agree with Chris for once!
09-10-2004
On second thought, get a Hallman :bounce: J/K, I loved my Joe P.
The GReddy Profec-B is the bomb, get it.
09-10-2004
-E
Mine has a bleeder hole under the screw knob and I was leak testing my setup and noticed that the hole leaks precious boost..
Does anyone know why they need a bleeder hole, because technically that is a nice boost leak.
I have a joe p.
09-10-2004
Business as usual
Get a Hallman. I may have a extra if you haven't ordered one yet. You could also make your own if you want.
Peter- They sometimes drill a hole on the "outlet" or wastegate side of the mbc. That is a good thing. It releases the pressure when you get off the gas (whenever the bov goes off) and allows the wastegate flapper to close quicker. If there is not a bleed hole, it takes longer to close the wastegate as the gasses are holding it open. I have not noticed a difference in them though (hole vs. no hole mbc).
97 Viper GTS
09-10-2004
Business as usual
BTW, the hole will only leak if you are at/past your desired boost level. Meaning that it should leak in a boost leak test when you pass the level of boost you have the mbc set to.
97 Viper GTS
09-10-2004
Business as usual
It should not leak then as the hole sees no boost until the boost controller is opened. You could have your boost controler out too where the boost controller is doing nothing at all. Meaning it would leak at a normal rate. If you have the mbc set to 10 psi, it shouldn't leak. Do you get what I am trying to say? You are probly letting the wastegate actuator set the boost instead of the mbc.
97 Viper GTS
09-10-2004
We don't use any MBC other than the one from Elite. Gotta go with that works, is local, and is cost effective.
09-11-2004
k thanks, i'll look into getting a JOE P MBC...
09-11-2004
or you could drive over to Elite Auto in minneapolis and get one for less money, that works as well, the same day!!
