Old 08-22-2004   #1
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Okay...can someone on here explain boost spike and how to stop it? I have a TurboXS HPBC on and when ever I'm on the highway and I go from 5th to 3rd or 4th, the boost shoots all the way up to around 18 and then quickly drops back down. I have the boost set to 14-15 lbs, but it doesnt go right to the setting... :headache:
Old 08-22-2004   #2
Could be a lot of things. Boost leaks can cause it to happen. Internal wastegates reacting too slow. Not a big enough bleed hole in the boost controller to release trapped pressure can do it.
Old 08-22-2004   #3
Enes
Enes's Avatar
run your bov and vg off the intake manifold not of the turbo. block off the line going from turbo to the mbc from mbc to the vg.
The best setup i have seen working is from the intake mani to the bov t'd off to mbc and from mbc over to the wg. That has proven on few dyno runs i have vitnesed with boos spikes and then after they have moved it over it stabilized. Same thing hapend on mine too.
-E
Old 08-22-2004   #4
Are you drunk or is that just your accent?
Thats a good point also though.
Old 08-22-2004   #5
1slowdsm
1slowdsm's Avatar
Right now I have my BC hooked up the way you said and it was spiking. I gotta do a boost leak test soon and if there is no leak, then I'm guessing its gotta be the wastegate. This is the same BC that Mike from QPR was using on his car, he sold it to me and now I'm getting boost spike. I have increase the bleed valve and see if that helps a little.
Old 08-23-2004   #6
Enes
Enes's Avatar
leme think it in bosnian.. then rearange the order of words and then translate it into english...
you suck all
i mean you all suck..
No i was in a hurry when i wrote that sorry.. and i do not drink alcohol so i can't be drunk..
-E
Old 08-23-2004   #7
john
Business as usual
john's Avatar
The running of the vacum lines shouldn't matter as I have run a mbc off my turbo for a while without it ever spiking. I have seen boost controllers cause it but not on such a low boost setting.
97 Viper GTS
Old 08-23-2004   #8
Enes
Enes's Avatar
It could be in conjunction with more restrictive IC and IC piping because there would be more back preasure before the IC rather than after hence why it would raise and then fall back down to certain preasure..
-E
Old 08-23-2004   #9
Raptor
ConArtist
Raptor's Avatar
Because of the 2 adjustments, it takes some time to do the tuning with that MBC. use the course adjustment as much as you can to get close then only use the fine adjustment as little as possible to get it set. It took a fair amount of time to get it set in my car then it was very stable for the entire time I had it.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 08-23-2004   #10
1slowdsm
1slowdsm's Avatar
Right now the BC is still at the presettings, I havent turned the course setting up or turned the bleed up at all. It shouldnt be set to 14 lbs right away should it?
Old 09-14-2004   #11
1slowdsm
1slowdsm's Avatar
I dont know of any other way of tuning the boost controller. I've tried turning down/up the bleeder and I've tried turning down/up the coarse setting, but I still get the same results. I might have to try out Elites MBC and see if its the old boost controller or if its something else.
Old 09-14-2004   #12
Jacek
Captain J-Sack
excuses, excuses..
mine old car use to spike 2psi and drop right away and that was with the original vacuum line setup.
Old 09-14-2004   #13
1slowdsm
1slowdsm's Avatar
If it was only two psi spike on my car, I wouldnt really mind. But I have it set to 14 and it spikes at 19.
