Old 09-30-2004   #1
I bought an MTX RT2400 amplifier off ebay from a big seller.
Finished hooking it up tonight, hooked it all up right and made sure (triple checked it). Well I finished hooking up the fuse holder and connected the 60Amp fuse for one second and then I heard a quiet pop coming from the trunk (I was under the hood).
I take the fuse out quickly.. I was basically just holding it together to see what would happen when its connected all up. Well I go back to the trunk and theres smoke coming out of the bottom of the amp. I look at all the fuses (the 60A up front-and the 2 30 amp fuses on the amp and none of them are burnt up...
Thats why Im wondering WTF happened and was it just a POS from the start? I havent contacted the seller yet but will tommorow unless anyone has some advice.
-Peter
Old 09-30-2004   #2
I'd just pop the cover off the amp and take a look. Not that it matters but did the remote wire have power at the time?
Old 09-30-2004   #3
The car was off so the remote wire shouldnt have had power. Ill pop the cover and take a look, also tommorow Ill check all the connections over again with test light.
Im just surprised it the wiring has a short why the fuses didnt blow.
Old 09-30-2004   #4
LightningGSX
Hellbound
Thats usually what happens when power and ground are reversed.If you're sure it was hooked up correctly, it was probably defective in the first place.
-Nulli Secundus-
Old 10-01-2004   #5
INTRIGUED
insert witty title here
INTRIGUED's Avatar
Drives: VW Gti
I'd say, if you want my guys to take a look at it PM me. I will get it fixed or at least find out what happened. I have a pretty good connection to people up here in Dull-luth that will give me a decent price on anything. Let me know.
Old 10-01-2004   #6
IneedaGSX
Send a message via MSN to IneedaGSX
Hey if you need a multimeter pm me I should have one as of monday.
:goodluck:
Anyone know anyone with a GSX 2 Gen for sale with a manual?
IneedaGSX is offline   Reply With Quote
Old 10-01-2004   #7
Well I ran all new power cable again just to make sure there were no shorts in the cable and I grounded it in a much better location but the unit seems to be garbage.
Now I can hook up the power wire but when you turn the key on and the remote signal turns the amp on it does the same thing (sparks and smoke).
So I emailed the seller and wish me good luck!
