Old 10-18-2004   #1
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I have been looking more and more into the cost of building a motor. I am pretty much set with Wiseco pistons, but am debating wether I want Eagle rods or Scat rods. I have been reading a decent amount about them and am finding that the Scats are very similar to the Eagles with an exception where the Scats add an extra oiling path, which seems better to me at least. The Scats are a little cheaper and they come with the appropriate ARP hardware, which brings down the cost more.
My question is, I have seen and heard good experiences with the Eagles, but have heard very little about the Scats in a real world application, does anyone here have any advice on the choice? I am not going to exceed 500 HP so either rod would hold up. It will be a 4G63, and probably see 30~psi with a 75 shot of nawz. If that helps.
Thanks in advance.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 10-18-2004   #2
Eagles come with ARP hardware also.
How do you plan on not making over 500hp with 30psi and a 75 shot? If you are serious about running that much boost with that big of a shot then you might want to skip right to some Crowers. A 75 shot on top of 30psi isn't a mild setup. You might want to get the block O-ringed also to try to help keep the nitrous in the cylinders. I would feel much safer running 35psi all day vs 30psi with a 75 shot ontop of it.
I don't know much about the Scat rods besides that they are inexpensive and have a questionable name.
Old 10-18-2004   #3
PSI2HI
Send a message via AIM to PSI2HI
If you dont break 500hp on that much boost and the N20 you got some issues or a really shitty tuner...
PSI2HI is offline   Reply With Quote
Old 10-18-2004   #4
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I guess I was a little off with that. Those settings would be track/dyno only. And I am thinking that 30psi is a bit high now that I look back. The car is mainly going to be daily driven. But I suppose that the crowers might do me well as to not limit me if I decide to slap a bigger turbo on there.
Thanks for your input on the rods Shane, I too questioned the name and price. Now I just gotta find a good price on Crowers.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-19-2004   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Scat makes decent rods for chevy small blocks but I dunno if their 4 cyl stuff is any good. I'd go with Eagle or Crower.
Old 10-19-2004   #6
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
have people had problems breaking the eagle rods with over 500hp?
7/25/09
Old 10-19-2004   #7
Raptor
ConArtist
Raptor's Avatar
Eagles are fine, Crowers are excellent but spendy however if you want a solid setup with big power, I would run the crowers. I don't think I would trust the Scat stuff, I have heard a few issues with there parts with domestics, more the cranks, but quality control is a company wide issue so you have to wonder.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 10-19-2004   #8
Someone can break 500hp with a 75 shot on a 14b.
He never specified what turbo he was going to use .
I've heard of the issue that mike was talking about, probably at the same time, lol.
Ghettostyle-
No-one has broken an eagle from 'power' yet as far as I know. John is using eagles (500+whp), as well as a few others.
Old 10-19-2004   #9
PSI2HI
If Eagles broke @ 500whp that'd be sad. I've been using stock rods for years making 500+ and reving to 8200.
I'd just save the $$ and get Eagles if you only plan to make 500whp. I've heard of that nation wide problem w/ the Scat products bu it hink that was awhile back now and problems have been fixed. There's also guys who race about the Scat rods as well. Either way @ 500whp i dont think you'll be breaking any rods. Seen a couple threads on some Honda boards of guys overring motors and the pistons shattering but the Eagle rods were all still straight and in spec after hitting 12k+ rpm.
Old 10-19-2004   #10
Raptor
ConArtist
Raptor's Avatar
The problems I have heard with Scats products were poor quality control related. The cranks were coming out all over the spectrum for tolerances and way out of balance etc. Not just one, but most of them. And this was recent (within the last year or two) That tells me the company doesn't do enough for quality control and if that is the case, I would call it a risk to use their stuff, no matter how cheap it was. Breakage isn't the only form of failure, poor performance from inconsistant parts etc is a worse failure in my book. When something breaks, you know it has failed, but if it isn't performing to design, you end up with a ghost in the machine you may never be aware of.. People should be able to identify issues like that on assembly, but there are just too many out there who don't check anything or at best just use that infernal plastigauge crap so finding those kinds of things will be unlikely. Stick with companies that use good methods across the board, they maintain good reps because of this and are worth the extra money because they take the extra time to make sure they are putting out their best.
651-488-7774
Old 10-19-2004   #11
Well, he said he was going to run 30psi. That isn't going to be a 14B or 16G. A 20G won't even hold 30psi worth a crap.
H-beam rods like the Eagles are supposed to handle RPMs better, while I-beams like Crowers handle power better. It's hard to compare a DSM to a turbo Honda with 123ft-lbs of torque.
Old 10-19-2004   #12
123 ft.lbs?
gotta be on the spray .
Like everyone else has said, eagles should be good for consistant 500whp.
Old 10-19-2004   #13
I hope the Eagles hold 700whp and 600ft-lbs of torque. My tranny will probably break again before the rods do.
Old 10-19-2004   #14
Matt have you looked at any of the other rod models available from BPM, Carrillo, Pauter, or Oliver?
...Just throwing out some other possibilities....
Old 10-19-2004   #15
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
stock or race tranny? Sorry for being off topic
7/25/09
Old 10-19-2004   #16
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
I already broke a race tranny.
'04 Honda Ricer: stock
Old 10-19-2004   #17
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Jakey, I have only really seen Carillo(nothing bad so far). I haven't seen anything from the others you listed, got any links?
Thanks.
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-19-2004   #18
Carillo: http://www.slowboyracing.com/shop.php?sid=&cat=201
Manley: http://www.slowboyracing.com/shop.php?sid=&cat=203
(I forgot about these)
Pauter: http://www.horsepowerfreak.com/PAUT_RODS.asp
(Mike - 1_vicious is running these in his Magnus Beast)
BPM: I can't seem to locate a link
Oliver: ^^^^^^^^^^^^^^^^^^^
All kinds of good rod info:
http://www.dsmtuners.com/forums/showthread...ad.php?t=117228
Old 10-19-2004   #19
Raptor
ConArtist
Raptor's Avatar
Carillo has made excellent rods for years, they are definately a decent option. They are strong and pretty light and they have options between "H" beams which weigh 565 Gr each or the slightly less beefy "A" beams which weigh 515 Gr each. They are somewhat spendy but a good rod. However, for the cost, I would still say take the Eagles, they are the best deal cost/strength for an engine in the range you are looking at. The Crower and Pauters are stronger but you will pay for it and they both weigh more which does also matter. There are other options out there, but unless I got them recommended by someone I really trusted or they could back up claims that they were better, I wouldn't waste too much time investigating them.
Oh yea, Manley rods are okay, but for the same money, I would go with the crowers any day.
651-488-7774
Old 10-21-2004   #20
Originally posted by Raptor@Oct 19 2004, 08:55 PM
There are other options out there...
So for those of us who are curious about the other options, what are you referring to Mike?
