Old 11-02-2004   #1
SlowWhite
Been there, done that.
SlowWhite's Avatar
DSMLINK AntiLag Feature
What can you tell me about Antilag. What are the Pro's/Con's.... In setting it up what should I be looking at as far as Setting it up.
How much timing needs to get pulled, What RPMS should I set it for, things Like that.
I'm trying to get an understanding of the theory in order to help me figure out how I want to set it up.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 11-06-2004   #2
1badgsx
It makes alot of noise! Its fun to launch with it. Make sure you have a very good clutch. I used it in my 98 GSX when I had the Fp3055 in it and used DSMLink default settings. If you knock just pull more timing.
Working in a 2nd Gen Engine bay is like playing Tetris.
1997 Jeep Cherokee (For-Sale)
1998 GSX
1997 AWD Talon (12.5@113 while breaking in third)
1badgsx is offline   Reply With Quote
Old 11-06-2004   #3
LightningGSX
Hellbound
Make sure you monitor your EGTs.The more timing you pull during antilag, the more heat and stress you're putting on the turbo and manifold
-Nulli Secundus-
Old 11-06-2004   #4
Go with the default setting first. It was good for 12-15 psi on my GT.56 in nuetral.
Yeah it will scare old ladies and wake the neighbors. I never looked, but I would bet that at night it's throwing flames out the tail pipe . It makes some really loud popping in the exhaust.
Old 11-06-2004   #5
Shotgun!
Totenritt
Shotgun!'s Avatar
Turbine wheel and exhaust valves hate the anti-lag!
Old 11-08-2004   #6
stikx
Mr -
is this like a misfiring system where it keeps the turbo spooling?
Old 11-08-2004   #7
Yes it it.
Old 11-08-2004   #8
Enes
Enes's Avatar
yes there is fire out the back when you do it..
-E
Old 11-08-2004   #9
that happens to me when i eat too many BLAZIN wings at bw3
Old 11-08-2004   #10
What happens is the timing is retarded, and possibly extra fuel is used. With the timing retarded the combustion is happening so late that raw fire is exiting the exhaust through the turbo creating more heat and gas energy than would normally be created.
Old 11-08-2004   #11
95tsi
95tsi's Avatar
Drives: a pos
Anyone have any problems with it? I was trying to run in on my car but all I would get was lots of knock. When I was trying it out, I was getting around 21psi of boost at launch. ??
Old 11-08-2004   #12
That's alot of boost for not being under load. I would back that down some. That will help with the knock also.
Old 11-08-2004   #13
Shotgun!
Totenritt
Shotgun!'s Avatar
21psi? Good lord, that's no good. Jet's car at 15psi was enough to know i don't wanna be reborn as a clutch...
Old 11-09-2004   #14
john
Business as usual
john's Avatar
I am not so sure I believe 21psi on the line... I used to get 10-15psi on a 5-5.5K stutterbox. The longer you stay on it, it seems to build a little bit. I have it written in my ECU and I also have a MSD-DIS2 which I use for a stutterbox. I always show knock when I first get on it. Then I step off it and get back on the stutterbox and all is good. The knock goes away. What is the difference between anti lag and a stutterbox? I have never seen it shoot flames though... Not on my car or on Chris C's (V8KLR) old car.
97 Viper GTS
Old 11-09-2004   #15
0psi and mine still spins the tires out of control. The anti-lag is great for trying to keep boost between shifts, but not the greatest thing on the line, unless you have a 9500rpm revlimiter to keep the tires under control on the launch. I would rather use a simple 2-step on the launch and make as little boost as possible just to get a consistant RPM for each launch. Now if we had a RWD with wide slicks and traction/breakage weren't an issue then I would go for 20psi on the launch.
Old 11-09-2004   #16
Stutterboxes/2-steps are for holding the motor at a constant RPM for launching on any car, boosted or not. It does it by randomly dropping the ignition to cylinder to keep the RPM stable. Doing that just happens to make turbos spool somewhat also. They usually build boost slowly and with a bigger turbo, you might only see a few pounds of boost.
Anti-lag is specifically made to spool turbos. It usually involves retarding the timing a lot and adding some fuel. If setup aggressive enough, it can have a large turbo making 20+psi almost instantly.
Old 11-09-2004   #17
john
Business as usual
john's Avatar
Ok, I would get ~7 on the first backfire and it would keep hitting up to ~15psi on the old 50 trim. I never got a chance to launch the new turbo.
97 Viper GTS
Old 11-09-2004   #18
LightningGSX
Hellbound
Your ECU was probably pulling the timing to stop the knock
-Nulli Secundus-
Old 11-09-2004   #19
95tsi
95tsi's Avatar
Drives: a pos
Mine would pretty much just jump right to 21psi at launch. Thats with antilag activated. The NLTS I can kinda watch the tach between shifts and pull around 15+ psi on slow shifts. Kinda similar to a rolling launch if you shift slow enough.
So far, my car has run the best with just the dsmlink lauch set at 5500rpm and the anti lag feature turned off. I would always pull too much knock to get the anti lag setup to actually be benificial off the line.
Old 11-09-2004   #20
The anti-lag feature drops out once the car starts moving, same as the stutter-box, so you should get your timing back, unless you are knocking. If I remember correctly you can set what mph for it to release at, but I can't say for sure since my car is not together yet. If anybody else knows, chime in.
