Old 02-04-2005   #1
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
Send a message via AIM to GSXMatt
Problem Diagnosis...Throwing Belts
Alright so a few weeks ago I was out playing in my GSX. Suddenely the car lurched and I lost power steering and stuff.
Basically threw my Water Pump/Alternator Belt, and the Power steering belt went as well.
Alright so got that fixed, found another problem, and fixed that as well.
I left tonight to go wash my car because it was dirty as hell. Just as I got into the carwash, it made the same lurch it did before, and I knew that it had just thrown the same belts.
Why is it doing this? I called Dane and he said it had happened to his Galant and it may be a Harmonic Balancer.
Any other ideas? Or is it indeed the Balancer? Thanks for any replies!!
GSXMatt is offline   Reply With Quote
Old 02-04-2005   #2
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: Problem Diagnosis...Throwing Belts
Move to correct section. FUCK!
CRAIG
Old 02-04-2005   #3
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Umm, try moving the balancer, if it's dead you should be able to slide it in and out on the carnkshaft.
Old 02-05-2005   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
My balancer could not move by hand. Start the car and look at the balancer from the top, see how true it spins any static, left to right or dynamic, up and down than the balancer is shot, also you may have an oil leak from the bad balancer and the added vibration like I did. Dam I'm tired I'm going to sleep. zzzzzzzzzzzzzzzzzzzzz
Old 02-05-2005   #5
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
I had that same problem when my balancer went out. I found out when I looked down at the spinning crankshaft (with the new belt on) and saw it moving in and out slightly. It almost looked like it was bent but the rubber inside there had worn to the point that it became a 2 piece crankshaft pulley (2 separate pieces).
Old 02-05-2005   #6
Do you have the water pump pulley on backwards?
Old 02-05-2005   #7
GSXMatt
GSXMatt's Avatar
Not that I know of?
Old 02-05-2005   #8
santa
Boost Spike
santa's Avatar
Miss alignment will deffinatly do that to belts. Check all of it out running and not running. Tighten the belts up some more also.
Old 02-05-2005   #9
My vote goes for this too.
Old 02-06-2005   #10
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Unless he took off the water pump pulley sometime in the very near past, I don't know why this would be a problem. There would have been no reason for him to take off the pulley if he only replaced an alt. belt.
Old 02-06-2005   #11
GSXMatt
GSXMatt's Avatar
Yeah I dont think I ever actually removed the pulley
Old 02-06-2005   #12
Quoting from memory, if you put the water pump pulley on backwards, it'd be hitting the frame rail.
I had this same problem when I removed my power steering pump and the inner pulley on the water pump. Just that tiny offset caused me to throw a belt after 50 miles.
Old 02-07-2005   #13
No, it won't hit the frame, at least it didn't on my car. I accidentally put it on backwards when I did a head swap in the QPR parking lot. It tossed several belts until I got a good one on there.
It is very easy to get in on backwards, one side just has a bigger offset.
