Old 12-28-2004   #1
MODS List
I know you've all been waiting for me to get off my ass (actually out of the driver's seat ) and write down my mods list.
Before anybody starts climbing the walls and starts saying there are things in this list you don't really need, they are there because I wanted them there and for my own reasons, so deal with it.
Here it is;
ENGINE:
Magnus Motorsports Stage 4 1G 2.4 L 8.5:1 Long Rod short block (Ross/Pauter)
Magnus Motorsports Stage 3 1G cylinder head (Supertech components, Cometic HP, ARP studs)
Magnus Motorsports sheet metal intake
Magnus Motorsports 1G/2G install kit
HKS 272/272 cams
Fidanza adjustable cam gears
Concept Racing solid lash adjusters (16 of them, and yes they are a bitch to adjust)
1G external oil cooler/oil filter housing
Setrab 119FP8 fan-pack oil cooler
-8 braided stainless steel lines from housing to cooler and back
Jaz mini breather catch can
FUEL:
Bosch -044 fuel pump (330 lph @ 75 psi)
VPE big bore fuel rail
Earls -8 1-way check valve @ inlet to the fuel rail
FIC 1000cc Ball/Disc injectors
Aeromotive A1000-6 1:1 AFPR
Aeromotive 12301 fuel filter
-8 braided steel line from the screen pick-up to the fuel rail
-6 braided steel line from the fuel rail to the AFPR
-4 braided steel line from the AFPR to the return line
1G throttle body/2G TPS
Fuel pump re-wire w/10 gauge wire
FUEL MANAGEMENT:
DSMLink v2/2.5 client software
MafTranslator v2.01
3.5 inch LS1 maf
AEM UEGO wide-band controller w/add-on a/f gauge
IGNITION:
AEM C2DI
Buschur Racing COP
93-94 Hall Effect CAS
TURBO:
DN Performance DNP-26 s/s tubular manifold
VPE GT3056 GT/BB turbo (hopefully will become a GT35R soon)
VPE external/internal s/s O2 housing
Tial 40mm wastegate
GReddy Type-s BOV
GReddy Profec-b boost controller
GReddy 24R FMIC and pipes
Dejon Tools GM Maf intake pipe
HRC lower turbo to intercooler pipe
HRC upper intercooler/bov pipe
Modded UICP going to Magnus intake
TRANSMISSION:
TRE race prepped transmission
Speed Design 4-spider center diff
Torrington bearing mod @ center diff
3-4 hub sleeve upgrade
Cryo treatment on all hard parts
CLUTCH:
Clutch Masters 2500lb pressure plate
Clutch Masters ceramic 4-puck sprung hub disc
Clutch Masters billet aluminum flywheel w/steel face
COOLING:
Fluidyne radiator
Fal Twin-line fans
160 deg thermostat
EXHAUST:
RSR 2.5 to 3 inch down pipe
APEX-i N1 3 inch cat-back exhaust
HRC super-duper high flow 3 inch cat
I would like to thank Mike (Raptor), Shane (ecoli) and regardless of some problems, Marco (Magnus Motorsports "porn king") for their help in this build-up. I've talked to them all several times and they have been a great help everytime it was needed.
-1ViciousGSX
You can click on my home page below for more info and pics of my set-up, fuel system and oil cooler installation. If anybody would like the fuel system or oil cooler mods put into the "Good Stuff" forum I could write it up. Just let me know.
http://www.cardomain.com/memberpage/225656/1
Now, back to the driver's seat
Old 12-28-2004   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: MODS List
Seems small, but as long as you can set the pressure were you want, it doesn't matter.
Old 12-28-2004   #3
Re: MODS List
43.5 psi at idle with vacuum the line off. Drops into the mid 30's at idle with the vacuum line connected. No over-run problems.
Old 12-28-2004   #4
MustGoFaster
Re: MODS List
Just get the break in done and go have some fun.
Old 12-28-2004   #5
Re: MODS List
It's at 630 miles now, the fun is already starting. Just finished callibrating the MafTranslator set-up to match my hacked 2g mas. I had one of my Fal cooling fans go out last night and am waiting for the new fan motor to arrive, should be here tomorrow.
BTW, for those of you (and you know who you are) that 1 year ago said I was wrong about having my engine run cooler than stock and that it would never work, YOU WERE ALL WRONG AND I WAS RIGHT. I am cruising on the highway at 163 deg steady. With DSMLink set-up to add 20-25 deg to what the ECU sees, and with my fans coming on when needed, I do not get over 189 deg sitting in traffic. BTW, did I mention I WAS RIGHT?
Old 12-29-2004   #6
Re: MODS List
One thing that is not in the list is a wide-band O2 set-up. I'm currently looking at a couple of options. Anybody have any personnal experience with or recommend one?
Old 12-29-2004   #7
Re: MODS List
wow, wish i had money!!
Old 12-29-2004   #8
Re: MODS List
I "had" money, but now it's all gone. In typical fashion, my driver's outside door handle popped off in my hands today. Gotta love it!
Old 12-29-2004   #9
Raptor
ConArtist
Raptor's Avatar
Re: MODS List
The PLX ones are pretty decent, we have a few customers running them and they have a pretty quick sampling rate and not that expensive. One thing i was going to suggest to you with the expensive new engine and turbo is an oil accumulator. For less than $300 it is probably a pretty smart investment, not only in the event of a unpredicted pressure loss, but just so you can pre-lube it. We are suggesting that to anyone we build an engine for now.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 12-29-2004   #10
Re: MODS List
I have the OZ/techedge O2 sensor and I really like it. It is not very expensive and works well. At the time they were one of the only ones using the VW sensor, but now there are a bunch. It works great with my AEM.
Old 12-29-2004   #11
DSMkel
Send a message via AIM to DSMkel Send a message via MSN to DSMkel
Re: MODS List
That's a big list.......
Type-Arrrrgh KILLA
"If it's never broke you're not driving it hard enough"
DSMkel is offline   Reply With Quote
Old 12-29-2004   #12
Jana
Mazda Bitch
Re: MODS List
Yeah, that's a big expensive list. Congrats Mike I hope (and pray) it runs long enough for you to make it to the track at least once!
Old 12-29-2004   #13
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: MODS List
Nice mod list. Now time for a real turbo and some healty boost levels to top it off
'04 Honda Ricer: stock
Old 12-30-2004   #14
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: MODS List
can you put the fuel system mods into the good stuff? Thanks
7/25/09
Old 12-30-2004   #15
Re: MODS List
Looks like a 5-point cage should be in your future if not already. I have a line on a T66 ball bearing laying around.
Old 12-31-2004   #16
Re: MODS List
Tell me more about this turbo.
Old 01-03-2005   #17
ipt
Re: MODS List
What is the part # for your fuel pump and where did you get it? I have heard of that pump before, but could never find it.
ipt is offline   Reply With Quote
Old 01-03-2005   #18
Re: MODS List
All OEM Parts Inc.
1-888-628-3247 ext 309. Ask for Eric.
$280.00 + shipping. Plenty in stock.
Bosch part# 0-580-254-044
Old 01-03-2005   #19
LightningGSX
Hellbound
Re: MODS List
Originally Posted by 1ViciousGSX
All OEM Parts Inc.
Is that an inline external pump? Or intank?
-Nulli Secundus-
Old 01-03-2005   #20
Re: MODS List
Both, but you won't get it mounted in the sending unit.
Go to my homepage for pics and details.
