Old 05-04-2005   #1
TurboDomestics
TurboDomestics's Avatar
Oil on Valve cover
What can cause this^?
I thought maybe a valve cover gasket, since theres no oil on the plugs, but I figured Id ask the experts, since im a n00BY!
thanks alot!
-Charlie
Old 05-04-2005   #2
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
Re: Oil on Valve cover
i have that same problem with my dsm once in a while, i never thought anything of it until i read this post> i would also love to know what casues it to do that, and if it's bad what actions should be taken to fix it?
BKs50trimGST is offline   Reply With Quote
Old 05-04-2005   #3
TurboDomestics
seems like alot of oil to me though, Ive only been driving it for a week
Old 05-04-2005   #4
It is most likely your oil filler cap. There is a rubber gasket underneath it and it gets hard and oil leaks out slowly and pools in that area.
Old 05-04-2005   #5
BKs50trimGST
Post whore
hmm, i dunno because i did switch that rubber gasket your talking about and it still does it alittle, not as much as his though. maybe i just have a bad oil cap and alittle to much oil in the car. so it's no big deal> correct?
Old 05-04-2005   #6
Or the usual cracked DSM valve cover.
Old 05-05-2005   #7
Raptor
ConArtist
Raptor's Avatar
VC is not cracked, new gasket in place with and torqued to 3 ft/lbs exactly. My guess is also the oil cap. Bring it by Charlie, I will have a look at it. It is likely pretty simple.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 05-05-2005   #8
TurboDomestics
I was going to do that, but I figured you were pretty busy (as usual ) so I didnt want to bother ya.
but now that youve invited me, ill probably stop by sometime this weekend
Old 05-05-2005   #9
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
just pull the cap off and see if the rubber gasket feels hard. If it is, get a new one. I think they cost around 84 cents
7/25/09
Old 05-05-2005   #10
It's probably interchangeable with the Volvo oil cap gaskets. They are such a common failure that Borton keeps them in a box by the front counter.
