Old 10-11-2005   #1
95tsi
95tsi's Avatar
Drives: a pos
T28 results possible problem
Just kinda wondering what people have to think on the results I've had with my T28. I don't really know if they are avg. or doing better than the rest.
This is from this past weekend 10/8/05 at BIR doing 1.8 60', 12.44(best)-12.6x 1/4 at 110mph. This was on C14+ without the use of a wideband.
I was also having problems going over 20psi. It would get to mid 20 but not 21. It would spike from 21psi to 9psi then back up to 20psi. Over 400rpm (5300-5700rpm). Any ideas?
Dsmlink showed:
Rpm: 6260
A/F: 11.51:1
MAP: 18.8psi
Inj duty: 82.6%
Timing: 18.1
Knock: 0
Intake temp: 52deg
Front O2: .90v
Airflow: 33.4lb/min
Cool temp: 203deg
Airflow: 252g/s
Old 10-11-2005   #2
Onefast99gsx
Re: T28 results possible problem
Your dsmlink results don't show anything out of the ordinary as far as showing the problems you were having. Go out to dsmlink and post a log. I have dsmlink too. Too hard to tell with fixed data like you posted.
