Old 03-20-2006   #1
Car Stuttering,ECU Capacitor replacement?
So i was driving my car home tonight and either when the car would close to 0psi or about 2200 rpms, the car would try to kill itself. I started it up, waited for a minute then started to drive. I usually start the car and then let it get completely warm before driving then it usually doesn't have any issues.
Tomorrow i am gonna look up the cap #'s and replace them. If anyone has any suggestions/helpful tips, basically anything to help. Please let me know.
I haven't replaced the caps yet, it is a eprom ECU, where could i get the socket and caps. I will lookup stuff tomorrow.
Thx
Aaron
Old 03-20-2006   #2
tim
tim's Avatar
Re: Car Stuttering,ECU Capacitor replacement?
Do a search on caps with the author as LightningGSX. I know he has posted the part numbers and where to get them before. I also know people sell them on eBay but overcharge on both parts and shipping.
Oh, and I dont think you will be able to get them tomorrow. I am pretty sure you will have to order them. I may be wrong though.
Old 03-20-2006   #3
Berda
Berda's Avatar
Send a message via AIM to Berda
I dont know much about DSMs (yet), but to me it sounds maybe like a warm start issue. I kinda have the same prob as I think ur describing but im not sure. Try checking your blow off valve tube that vents the puff of air back into the sys, it may be leaky/unplugged/ect.
In order to vent to the atmosphere, you need to change some stuff i.e. Maf and maf trans, or dsm link, or AFC. Ive been researching on venting to atmosphere for my stock 91 AWD and from what i understand, you CANNOT vent to atmosphere on a stock setup by simply unplugging that tube that vents it back into the sys like right b4 the turbo, you need the "supporting mods". \
-Adam
'91 TSi AWD Stock - 161.7 AWHP! Sold :(
'99 Honda Accord EX Coupe V-6.
Berda is offline   Reply With Quote
Old 03-21-2006   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
-Adam
I think it has more to do with the car and what BOV you are using. I think some cars respond worse than others when you vent to the atmosphere. My friend had his get disconnected once and it ran like crap. The 1g bov I had on my car caused no problems when it was vented for me.
7/25/09
Old 03-21-2006   #5
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Yeah mine ran a little rich but it didnt ever die when I vented into the atmosphere.
-Colin
Old 03-21-2006   #6
my car is in stock config. only mods are egr blockoff, boost gauge, boost controller. free mods.
Old 03-25-2006   #7
tim
tim's Avatar
Hey, I found this write up on replacing the capacitors. It also tells where to buy them online and the part numbers.
http://www.tmo.com/howto/ecu1g/caps.htm
Old 03-25-2006   #8
thx, man i found the caps at ax man, and then i had LSE do it, cause the damn soldering gun had couldn't get them loose. I am gonna go try it out now.
thx all
Old 03-26-2006   #9
Alright, drove car last night, still sucks. Until car heats to normal temp (gauge is about 1/2/pointing straight up) the car will not go over 2000rpms, or 0 psi. when it hits 2000rpms the car just cuts itself off, of fuel or something. Pls help, i am gonna check some stuff out when i get done with h-work later.
Thx
Aaron
Old 03-26-2006   #10
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
have you checked boost leaks?
7/25/09
Old 03-26-2006   #11
i have to do that yet, actually the only problem i have now is the cold start issue as stated above.
