Old 04-25-2006   #2
blageo23
AWD4G64
blageo23's Avatar
Re: Which swap method did you use?
I did the magnus way. Only problem is that random misfire code which I only got 1 or 2 times last year. The most practical for a DIY-er is the magnus. The RRE is alot of machining but it allows you to keep your crank sensor which most people say is the cause of the misfire code.
Old 04-25-2006   #3
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I used the magnus way and didn't have misfire issues. I have dsmlink which can prevent it also though.
7/25/09
Old 04-26-2006   #5
If you have DSMLink or an AEM, you can do it the Magnus way.
Old 04-26-2006   #7
Do it the Magnus way while using the RRE adaptor harness. That's what I did.
