Old 05-09-2006   #1
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Arrow Car doesn't want to rev!
Problem - Car idles on it's own and will rev normal until only about 2k RPMS. It is extremely hesitant past that. The stock boost gage is reading 14psi and the car is on jack stands. The after market boost gage reads no boost. I know the stock gage is POS but I'm guessing that it's showing a problem since it should not pass zero in neutral. I think it could be the TPS.
History with the car - We rebuilt the bottom end of the motor. It's a 91 TSI awd turbo talon. It has a MBC, volt meter, "a/f gage", boost gage, 2.5 inch exhaust. The car is mainly stock. The timing belt is correct, but the ECU timing isn't set. Regardless to if the cas is inverted or anywhere it can possibly go, the same problem exists. I know the timing needs to be set but I've never done it before and I don't have access to a timing light / alligator clip at this time. I've swapped both the CAS and coil pack off a perfectly working dsm and the problem didn't get any better.
- Josh L.P.
Old 05-10-2006   #2
Berda
Berda's Avatar
Send a message via AIM to Berda
Re: Car doesn't want to rev!
check the mass, and boost leaks
'91 TSi AWD Stock - 161.7 AWHP! Sold :(
'99 Honda Accord EX Coupe V-6.
Berda is offline   Reply With Quote
Old 05-10-2006   #3
Pimpin Dsmstyle
Br0k3N
If I knew how to use a volt/ ohm meter or read schematics.. I might have some luck there. But since I don't - pretty much shit outta luck. If you need anymore parts I have - im sure we could arrange something
- Josh L.P.
Old 05-10-2006   #4
Pimpin Dsmstyle
Br0k3N
There is a lot of popping / back firing going on also. The plug that goes into the idle motor thing makes weird crackling sounds when the car is in the on position.
- Josh L.P.
Old 05-10-2006   #5
tim
tim's Avatar
Is the ECU a known working ECU?
Old 05-10-2006   #6
Fix what you know is wrong before anything else. Get up to an auto parts store and buy a timing light or find someone to borrow one from. If that doesn't work check your plugs and wires, after that do a boost leak check. Check out that crackling sound too, DSM's make lots of weird noises when first put in the "ON" position, but if it continues more than a second or two you have some issues. Like noted above, also confirm your ECU is good.
Old 05-10-2006   #7
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Is the mas plugged in?
'04 Honda Ricer: stock
Old 05-10-2006   #8
Pimpin Dsmstyle
Br0k3N
Yes. I'm going to try a different one tomorrow.
The ecu showed no signs of any damage. It worked when the timing belt broke 2 years ago. I took out the ECU when I got it to check if it was an EPROM and there I didn't see any leaky capacitors and it didn't smell like fish.
My brother decided to try take out the ECU with a screwdriver and snapped 2 of the clips. They are in securely but I can't compress the clip to remove the plug because there is nothing there. That is a real kick in the face. I have a spair ECU at my house too. Suggestions? Besides kick him in the teeth, I already did that.
- Josh L.P.
Old 05-10-2006   #9
I bet your timing is messed up since everything was fine before you did the t-belt job. Double, triple, and quadruple check all the timing marks line up and the set the base timing to spec.
Old 05-10-2006   #10
Pimpin Dsmstyle
Br0k3N
The tbelt snapped on the previous owner. We have checked and re-done the tbelt. No change.
I just swapped MAF's and got no change. I will double check the timing belt a couple more times tomorrow. One time when we checked, all of the notches were good but the cam gears were SLIGHTLY out of line. It certainly didn't seem like it was off a notch, but we re-did it and got the same results AT FIRST. Then we proceeded to run the car looking for other things to fix 'till we figured that out. Once we were ready to do the belt again, we lined up everything and the weird thing was, everything lined up perfectly. I'm assuming the tension evened out and everything came out fine. Like I said though, I'll check again tomorrow. The timing belt takes like 15 minutes.
Tomorrow I should be able to use my buddies working TB / TPS. He also has a timing light. I need to figure out how to ground out the ECU though. I don't know if anyone will have alligator clips. I looked at the ground plug and it looked like it only had 1 metal prong and a purple prong. Is that right? This is the plug that has no plug-in besides the "plug cover" that goes into it to prevent it from accidentally grounding out.
- Josh L.P.
Old 05-10-2006   #11
Pimpin Dsmstyle
Br0k3N
Could slightly bent valves cause a problem like this? I bought the head used and everything looked fine. I'm still going to do all of the other things on my checklist, but it's starting to look like it could be the head. The car smokes alot and backfires frequently - the smoke is grey. Now I am going to do a compression check as well.
- Josh L.P.
Old 05-11-2006   #12
Pimpin Dsmstyle
Br0k3N
different ecu fixed the reving issue. Smoke didn't go away. Decided to take it around the block - wouldn't boost and it died right before I got into my driveway. It seemed like a clean kill. Haven't determined what happened yet.
- Josh L.P.
Old 05-11-2006   #13
Good job on fixing the revving. Now you can't make boost, and you're still smoking. Hmm I guess I know what I'd be checking next!
Old 05-11-2006   #14
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I'd do compression and a boost leak tests.
7/25/09
