Old 06-13-2006   #1
kslice88
burnin oil and smoke out the valve cover
i have a non turbo 1g converted to a turbo. its the 2.0 and im runnin a 14b. i was in 2nd and i hit it and i was pushin around 10-11 psi when i heard what sounded like a coupler blowin off (which know i think was detination in one of my cylenders) so i pulled over and when i pushed in the clutch it died. all the couplers were still on and when i started it back up it started smoking outa the breather filter and outa the oil cap hole. i was leaning towards a cracked piston,at first i thought it was the rings but i havnt lost any power which makes me think cracked piston. just wondering what everyone else thought. any feedback would be helpful
kslice88 is offline   Reply With Quote
Old 06-13-2006   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: burnin oil and smoke out the valve cover
I have the same problem almost to the T and I have no idea what happened... I was driving shifting gears sounded and felt like a coupler broke off and pulled over to the shoulder pushed in the clutch and it died. Only thing with mine though is it was overheating at the same time... If an admin wants move my thread but if not I just gather up the info you tell him and go off of that... car is a stock 95 GSX
Old 06-13-2006   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
any ideas for the both of us
Old 06-14-2006   #4
kslice88
r u burnin oil? and lots of smoke?
Old 06-14-2006   #5
YiNYaNg
Hold Alt & press F4...LoL
YiNYaNg's Avatar
I say do a compression test. Seems like you guys have some blow by since smoke is coming out of your breather.
Originally Posted by ecoli
Some cars are so slow that even the cops can't tell they are racing.
http://www.myspace.com/kounpheng
YiNYaNg is offline   Reply With Quote
Old 06-14-2006   #6
kslice88
if its valve seals would it lower my compression because theres not much space inbetween the valves and the head. does that sound right or no? ill do a test soon and get back to u, thanks
Old 06-14-2006   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I dont know now it doesnt start
Old 06-14-2006   #8
kslice88
what is it doin? is it firering? do u have spark?
Old 06-14-2006   #9
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
its noy doing anything, when I try to turn it over its like the clutch isnt engaging
Old 06-14-2006   #10
YiNYaNg
YiNYaNg's Avatar
confused on what you're trying to say
Does the starter crank or no?
Old 06-15-2006   #11
kslice88
do u mean not disengaging?
