Old 06-28-2006   #1
95talonracer
95talonracer's Avatar
Check engine light question
Does the timing get pulled if the check engine light is on on a 95 tsi?
Old 06-29-2006   #2
tim
tim's Avatar
Re: Check engine light question
I am assuming your CEL is on? Get the code pulled if it is.
As far as I know the only time timing is pulled(due to knock) and your CEL in on is if you have a chip burned for it or if you have DSMlink and you have it set to do that. Otherwise I dont know, I am not sure if the stock ECU does that.
Old 06-29-2006   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
My check engine light is on and it's fine. I have no cat so it throws off my o2 readings. My car runs fine.
pics or gtfo
