Old 12-04-2006   #1
150lb injectors
Just throwing this out there in case anyone here has already done all the research, or has any input. I'm looking for some larger injectors and have been doing a lot of research. I was looking at FIC's 1600 injectors, which sell for 85/piece. But I'm always looking to find a deal. So I've been digging for alternatives.
Apparently that MNGSX guy off Tuners is running these Crown Victoria 150/160lb injectors. I also found him posting this in some biodiesel forums and what not too. So apparently they are working ok for him. I'm trying to find the best deal on these as I can. The only thing, is that I keep seeing similar part numbers, but they sometimes have 1 letter difference, and it gets kind of confusing. So if anyone has some solid part numbers that they know will work, please let me know. Here's what I've found so far...
FIC 1600's=85/piece
I first started out with this part number, and these injectors. 74160
Summit
Autozone Then started finding all sorts of part numbers. Here they want like 87/injector which isn't much of a deal. So I moved on.
Then I found out the have them at Ford racing parts for 275/set of 4.
Now, I'll just continue to list the rest of sites I've found. I haven't verified these part numbers yet, but here's what I've come across...
gefracing 245/set of 4
PART NUMBERS CM4980, F5TE-B5A, XL3Z-9F593-CA(this is a part number I got directly from the local dealers part department), F5TZ-9F593-B5A,
https://www.rockauto.com/dbphp/mfr,M...,Fuel+Injector
apparently those are all the same basic part, just by different manufacturers, some with core charge... Looks like they have an injector that is as low as 31/injector with a core charge.
http://www.directautomotiveproducts.com/322a1402.html
35/injector, again we see part number F5TZ-9F593-B5A
http://www.fuelinjectorsdirect.com/wizard/default.asp
65/injector, and again we see familiar part numbers such as F5TZ-9F593-B5A, and F5TE-B5A
PART NUMBER C1000-147879
http://www.prostreetonline.com/catal.../fuelinjector/
and
http://replacement.autopartswarehous...jector&dp=true
OK, anywho, just trying to share a little of my research. I'm sure I'll get plenty of the "Why not skip it and just get the FIC ones". But I'm always looking for the deal, and doing things a lil against the norm. And like I said, I've already realised I'm not alone, one other person that I know of seems to be using these, and who knows how many more. Just looking for a cheap alternative. If anyone else has any info on this, please add to this. I'm just trying to sort out all the different part numbers. But from what I'm gathering, a lot of these part numbers, are in essance the same part, just some made by AC Delco, some made by GB-Sorenson, some by AirTek, etc.
Old 12-04-2006   #2
Re: 150lb injectors
Lots of people are using the Crown Vic injectors now, you just have to modify the tops and use your own o-rings. I last saw them at $31/each new or next to nothing used.
Old 12-04-2006   #3
Thor06
11 Seconds to Freedom
Thor06's Avatar
Re: 150lb injectors
Wow! Thats great, how big does 150lb translate to in the metric system? Thank you Brandon, that is going to save me all kinds of money.
Old 12-04-2006   #4
Re: 150lb injectors
From what i have heard lately is that all the auto parts stores are out of the crown vic injectors, but Summit now has them for a decent price. I think it was $60 each.
Old 12-04-2006   #5
Re: 150lb injectors
150lb/hr is 1500-1600cc/min
Old 12-04-2006   #6
Thor06
Thor06's Avatar
Re: 150lb injectors
Do they work ok with DSMlink? What about fitment?
Old 12-05-2006   #7
Re: 150lb injectors
Some modification to the top is needed and possibly some extra electronics to get them to fire correctly.
Old 12-05-2006   #9
Re: 150lb injectors
Is the top just too big? Can you machine out the holes in the rail?
I found them at Summit for 67. Not too bad. But compared to these other sites that have them for like 30-40 a piece, that aint bad at all.
Old 12-05-2006   #10
Re: 150lb injectors
Well Jet you were right. I found a few places that were sold out, or had just 1 in stock. The Ford dealers want like 100 bucks per injector. Anywho I did find that one of the places I liked to earlier has them in stock, and ordered them. I spoke directly with one of the sales guys, and he made sure this was in fact the CNG stock replacement injectors, and apparently they have some more if anyone else is looking for more. He didn't tell me exactly how many more though. I got them from...
Old 12-05-2006   #11
Re: 150lb injectors
They'll work, you'll just have to tweak them a bit. I should get a set for my secondaries if these piddly 450's can't keep up with the twin Whinebro's.
Old 12-05-2006   #12
Re: 150lb injectors
1600's as secondaries, damn nacka!
Old 12-05-2006   #13
Re: 150lb injectors
You can modify the rail and use the o-ring setup they come with. I also thing that sounds like the easiest way. I have a nice reamer set that would work perfect for that. I can borrow you one.
Old 12-05-2006   #14
Re: 150lb injectors
I agree. It's not like these rails are hard to come by either, so I'd rather just drill one out and call it good. That's how we do it on the honda rails when putting in 450's.
When I get the injectors, and a new spare fuel rail, I'll hit you up, Thanks!.
I've also heard about people just using the stock o-rings for the top, and the stock rubber donut looking seal on the bottom, and it worked pretty well. I figure I'll just try a couple different methods, and see what seals up the best, and just go with it.
Old 12-05-2006   #15
Re: 150lb injectors
Then I'll copy what works best for you
Old 12-05-2006   #16
Re: 150lb injectors
Werd! Got any spare 1g fuel rails in that parts warehouse of yours?
Old 12-07-2006   #17
Re: 150lb injectors
Sure do!
Old 12-12-2006   #18
Re: 150lb injectors
Does anyone know at what ohm value we absolutely have to stay under on our injectors? I know our cars use low impedance, and if I remember right the stock ones are around like 3ohms? At what point is the impedance rating too high?
I seem to have found these for real cheap, but the impedance is a little higher then I'm used to seeing. Anyone know what is too high?
http://www.injectorservices.com/Flow...0280150837.jpg
Old 12-12-2006   #19
Re: 150lb injectors
Our factory ECUs are actually setup to run high impendance injectors. I am not sure what side effects there might be with too much resistance. Possibly not enough power to hold the injector open or slower response, but an extra 1.5-2 ohms over a commonly used 3ohm injector might not be enough to make any difference. If there was too much resistance, it wouldn't be that hard to get the system adjusted back to normal.
Old 12-12-2006   #20
Re: 150lb injectors
OK that make sense. That is why we have our resistor box, to knock down the voltage then I suppose. Now from what I gather, the disadvantage of higher ohm injectors, is a slightly slower reaction time. So if that became an issue with those you said it'd be an easy fix. Is there a way to bump up the voltage to the injectors, that I'm not aware of? Or what is the easy fix you're talking about? New resisitor box with slightly smaller resistors? Or are you just saying with some tuning it'd be an easy fix?
