Old 01-20-2007   #1
gsxer
DSMlink?
Well, I'm about to get a DSMlink and was wondering if it's just a easy just install ecu or do you need any other things in order to install it?
-yinchinzhong --cheng
gsxer is offline   Reply With Quote
Old 01-20-2007   #2
Re: DSMlink?
Yanking out the ecu is super easy, I think you just need a 10mm socket to get the mounts off. Will you be installing bigger injectors anytime soon? Learn how to use DSMLink as much as you can, but do yourself a favor and bring the car to a local tuner and have them tweak it, they will make sure it is making the most power it can on a nice safe tune.
Old 01-20-2007   #3
gsxer
Re: DSMlink?
Yea I have 650 cc injectors already is that big enough? Do you know anyplace that tunes dsmlinks? how much? thanks alot sheides
Old 01-21-2007   #4
Re: DSMlink?
Any of the shops can tune it.
Old 01-21-2007   #5
Re: DSMlink?
Yup, take it to any of our sponsors, they should be able to help ya out!
Old 01-21-2007   #6
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: DSMlink?
Are you getting a used dsmlink setup from someone else or a new one? If you aren't getting a used setup, you will need to get an eprom ecu if you don't have one and get it socketed so you can use the dsmlink.
7/25/09
Old 01-21-2007   #7
gsxer
Re: DSMlink?
Thanks, and I am getting a used one but I'm also getting a used already socketed 95 eprom ecu. Thanks guys for all the help.
Old 01-21-2007   #8
Shane55113
Now 20% less Racist
Shane55113's Avatar
Re: DSMlink?
Make sure you get there dsmlink account transfered to your ownership from www.dsmlink.com/forums . its the very best resource for dsmlink.
Old 01-21-2007   #9
gsxer
Re: DSMlink?
Alright thanks. So I just go on and tell them to transfer it?
Sorry noob when talking about DSMlink, but I've done some research.
-yinchinzhong--cheng
