Old 03-14-2007   #1
Tman1gtsi
Vibration from Front End
so I have gigantic boostin plans for this next month including an scm61 and fmic, 669's etc, but have noticed a vibration/rattle comming from front of car(91 tsi) occurs from 2400-2900 and is stronger on down shifts. Has not effected any performance, could it be my motor mount that is cracked, or could my driver side cr joint which is loose casue this, if so why only at those rpm's?
Thanks!
-taylor
Tman1gtsi is offline   Reply With Quote
Old 03-14-2007   #2
Re: grrrrrrrrrrrrrrr
It could be a million things. How bad is vibration? Does it happen in every gear?
Also, please use decent thread titles, especially for tech treads!
Old 03-15-2007   #3
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Vibration from Front End
Yea it could be a ton of things. I'd start by getting those few things fixed, esp that cracked motor mount.
Old 03-15-2007   #4
hrm, I misread that. I'd start with the cracked motor mount for sure!
Old 03-15-2007   #5
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Scheides, you were pretty much right with your first post.... More info is needed. There isn't going to be anyone that will be able to diagnose your problem over the intraweb, only give you some ideas of where to start looking. Your going to have to get in there, and inspect possible problem areas, and if you don't know what to look for, you'll probably end up having to bring it to a shop
Old 03-15-2007   #6
tim
tim's Avatar
What do you mean by loose CV joint?
