Old 02-06-2007   #1
thom1301
Winter/Wet Stability
I have an open-ended question to pose to all who'll listen. My '96 AWD Talon feels like it shimmys/swims/darts down the road when it slippery out (rain or snow). In fact, it feels much less stable at speed going straight or around corners than the FWD vehicles that I have owned. Is this normal? Would you guess there's something fishy about my alignment or front end parts? Maybe struts shot? My tires (BFG Traction TAs) are less than half worn.
Thanks for any help you can give me.
thom1301 is offline   Reply With Quote
Old 02-06-2007   #2
Re: Winter/Wet Stability
Check your alignment and for proper tire preasure.
Old 02-06-2007   #3
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Is this your first awd vehicle? My gsx feels like it slides around a little, but that's only cus my other fwd cars just spin when i accelerate. My gsx actually grabs a little.
pics or gtfo
Old 02-06-2007   #4
Are the tires too wide?
Old 02-06-2007   #5
I'm guessing alignment. AWD doesn't matter for straight line tracking.
Old 02-06-2007   #6
thom1301
Tires are the stock size and I just checked the pressure this morning.
Old 02-06-2007   #7
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
get an AWD alignment done. Or you just not use to the rear end pushing the car because of stated above. haha Just joy the AWD in the snow. Take her to a empty parking lot and get a feal of how she acts in the wetness
Josh LaCroix
Old 02-06-2007   #8
HiImBrian
HiImBrian's Avatar
Yea I really think you just need to get used to it. First time I drove I was slidin around, but now that I know how to drive an awd car its great! btw, what is the slip differencial from front to back on an awd dsm?
pics or gtfo
Old 02-06-2007   #9
kennydawgg
I had the same type of problem with my fwd, it was kinda like I had no control when there was water on the road. It felt like I was on a raft on a waterslide. My problem was camber angle, It had a bad toe in I believe, the tires basically looked like this \---/ because the previous owner had a different suspension with a camber kit to compensate for the lowered ride. Then he put it back to stock and did not set it back. ate through a new set of tires in less than 5k but only on the outside. Regardless though, I got the angles set back to normal and now it rides fine in the rain.
kennydawgg is offline   Reply With Quote
Old 06-04-2007   #10
thom1301
Just in case anyone has the same problem, my rear had way too much toe in. Both sides were out of spec, and the side that was more out of spec, was the side where the tire was more worn out. FYI
Old 06-04-2007   #11
2003eclipse
Slower than a rusty Honda
2003eclipse's Avatar
My buddies 2g FWD did the same, in the rain. There was a bushing in the upper rear suspension that was shot. Burned it out, pressed in a new one and the whole feeling of the ass end swaying side to side going straight down the road went away. So it happens to FWD also.
Just jack the car up one side at a time and do a shake down test on the tires. Check for loose ball joints/ bushings. Good Luck
I LIKE TURTLES
Old 06-05-2007   #12
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
X2, your tie rods should have no precevable freeplay at all. could also be an issue with caster/toe. oh and those tires suck BALLS!
can you be more specific? are you having to make constant corection to keep the car straight? if you let go of the wheel does it dart off to one side?
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
Old 06-05-2007   #13
Moved to Tech forum
Old 06-05-2007   #14
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
I'm going with alignment. When you have that checked they will be able to tell you if the car has any other related issues. AWD vs FWD makes no difference in feel when cruising. If you can feel a difference when you are going 70 down the freeway then either you are imagining it, your alignment is off, or your attributing some other factor to the AWD.
Old 06-06-2007   #15
thom1301
Thanks for the comments guys. Just to clarify, I had the problem, I've since had the alignment done, and the rear toe was way out of spec. I'm hoping that cures the stability problem as well as the tire wear problem.
