Old 02-25-2008   #1
Mistaspakles
broken off bolts, can anyone remove?
Hey guys. You know the five bolts that hold the top of the front bumper on? Well, four of mine busted off when I put back my OEM bumper. I don't want to take the time to remove the studs myself, so does anyone know of a place that will remove the studs?
Mistaspakles is offline   Reply With Quote
Old 02-25-2008   #2
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: broken off bolts, can anyone remove?
Drill them out and use self tappers.
Old 02-25-2008   #3
dont be lazy.
Old 02-26-2008   #4
Mistaspakles
yeah, I tried to drill them out, but my drill bit broke off twice.
Old 02-26-2008   #5
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
If you mean the small ones that fit through the bumper cover, I found the best thing to do was to use a drill bit just smaller that the bolt. After you get through pull it slightly to the side so the hollow bolt fragment collapses. This will leave the threads inside in good shape. You can then push out the remaining bolt piece and drop new ones in. No retapping needed.
Old 02-26-2008   #6
Mistaspakles
What do you mean by "pull it slightly to the side so the hollow bolt fragment collapses"?
Thanks,
Old 02-27-2008   #7
xveganxcowboyx
Wanker
Drives: 95 M3
Thanks,
You drill out the center of the bolt and make a thin walled tube out of it. When you pull the moving bit to the side it eats away one side of the wall. Instead of an "O" it is now a "C" and will collapse in on itself.
Old 02-26-2008   #8
A bolt extraction kit, or self taping screw/zip ties are needed.
Old 02-27-2008   #9
Zip ties, looks good and tested to over 150.
