Old 03-19-2008   #1
green hornet
WTB: CLUTCH ASAP by this weekend
i need a FWD 6bolt clutch by this weekend pref new'er, with very few miles on it stock, aftermarket dosent really matter PLEASE let me know if eny one has one!
sadly the one i have is for an AWD
Old 03-19-2008   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: WTB: CLUTCH ASAP by this weekend
They are the same clutch...
Only difference is the flywheel.
Go put the one you have in!
Originally Posted by shoutbox
Old 03-19-2008   #3
green hornet
i got a fidanza fly wheel and the AWD on didnt work on it non of the bolt holes matched up!
Old 03-19-2008   #4
green hornet
OMGGGGGGGGG! IM A DAM TARD HOLY MO&#&*(#&*(#ER
i would just like to state that it helps if i turn the hub a little bit! LMAO!!!
Old 03-19-2008   #5
green hornet
im stupid been workin on the car a little much!
Old 03-19-2008   #6
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Rotate the clutch until they do.
Either that or your clutch or flywheel is not for a DSM.
90-99 DSM clutches are all the same. The only difference is that the flywheel is different between models and years. The clutch will bolt up to all of the different flywheels.
EDIT: There ya go...
Old 03-19-2008   #7
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Care to elaborate a little. Are you saying act clutches only work with act flywheels and same for finanza etc?
pics or gtfo
Old 03-19-2008   #8
No, he is saying for a 1g fwd, you have to use that flywheel. The flywheel is different between most of the model breaks, but the clutch is all the same.
Old 03-19-2008   #9
green hornet
with the fidanza fly wheel i have the clutch hub dosent sit flush with the tabs on the fly wheel is that ok,
Old 03-19-2008   #10
What is keeping them from sitting flush? The fingers of the clutch should start to flatten out.
Old 03-19-2008   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
You need to torque it down... Use a torque pattern like a star, (like putting a wheel on a car) to make sure it gets torqued evenly and you dont warp the clutch, tightening each bolt 1/2 a turn or so until the clutch sits flush with the flywheel. Make sure the bolts are torqued to spec.
Old 03-19-2008   #12
Also, make sure you don't tighten it down until the clutch is on the car or you won't be able to get the splines aligned on the disk.
Old 03-19-2008   #13
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Good point, also make sure the clutch disk is installed the correct way otherwise you will snap it.
Old 03-19-2008   #14
green hornet
yea thats what i figured, i was just tripin out a little cause i have so much to do befor i put the motor in on friday, oh well thanks for straightining every thing out guys.
