Old 04-20-2008   #1
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
HELP! Gas is comming out my exhaust!
Alright, So I just got my motor rebuilt again, for the 4th time in its life. I just threw on an oem MLS head gasket, but im still rocking all my forged internals, and my hot cams... Im going to stay N/A for now, until I get the car running good, and the motor broke in real good.
I finnaly started the car today,
I drove it to town and came home (about 30 miles total) shut it off and let it sit for a few hours.
I went outside just a bit ago to drive it again and it had a super hard time starting, It chugged and chugged and It sounded like it was missing on one cylinder, and I have White smoke comming out my exhaust... after a little bit, i noticed some kind of fluid leaking out of the little crack in my header, I shut the car off and put some of the fluid on my finger to look at it and smell it... It was gas... Any Ideas on what I might have done wrong, or something broke?
MMFTW
Supa_dupa_man is offline   Reply With Quote
Old 04-20-2008   #2
crazy_skier
A.E.K.Δ.B
crazy_skier's Avatar
Beer Dude 2 Champion!
Drives: 1994 Suburban
Re: HELP! Gas is comming out my exhaust!
sure its gas and not oil??? I've had oil build up on the edge of my mani's before.... do you have the timing belt 100% correct??? maybe that could be letting some gas out before its burned...
Old 04-20-2008   #3
Supa_dupa_man
Bimmer Guy
Drives: ///M3
Ryan, Yes, my timing is on 100% perfect, My EGR vacum line was broke, so i replaced it with a rubber vacum line. I do have spark, compression is good accross all four, fuel output is normal, and fuel pressure is normal. Im 100% sure its gas and not oil. Im confused as hell.
MMFTW
Old 04-21-2008   #4
crazy_skier
A.E.K.Δ.B
Brandon..... hmmmm is it just running rich, aka bad front O2 or something???? i'm stumped to haha
Old 04-21-2008   #5
Supa_dupa_man
Bimmer Guy
Drives: ///M3
nope, brand new o2 sensor...
MMFTW
Old 04-21-2008   #6
Need more details on your setup. What size injectors? Are you using anything to control the larger injectors (if so equipped)?
Old 04-21-2008   #7
Supa_dupa_man
Bimmer Guy
Drives: ///M3
390cc injectors, 255lph FP, AFPR, 12:1 FMU... no wideband.... in the morning im gonna try using the stock FPR and injectors to see if that works...
MMFTW
Old 04-21-2008   #8
Try a stock fuel pump too, a 255 will overrun the stock FPR.
Old 04-21-2008   #9
Supa_dupa_man
Bimmer Guy
Drives: ///M3
kk, So today i popped in all four stock injectors and plugged in my stocker FP, also put the stock FPR back on... and guess what happened... NOTHING! It still has gas comming out the exhaust and its still chugging pretty hard...
MMFTW
Old 04-22-2008   #10
Jungy
Jungy's Avatar
Drives: 10' Sierra Denali & 99' beatervette
crane 18's + stock ecu = not a good mix
Jungy is offline   Reply With Quote
Old 04-22-2008   #11
Supa_dupa_man
Bimmer Guy
Drives: ///M3
Thanx a ton bro... Hopefully this is the only problem...
MMFTW
Old 04-22-2008   #12
Supa_dupa_man
Bimmer Guy
Drives: ///M3
Ok guys, here is the newest update... Before the most recient rebuild I was using an AEM F/IC on the car while running Crane 0018 cams... The motor blew, I sold the AEM, to get money to fund my turbo kit build up (Decided to rock manual fuel tuning) I rebuilt the motor and I am still using the 0018 cams... however, you can only run these cams with a Air and Fuel controler, or an electronic Fuel management unit. So this means I have to downgrade my cam size or get another AEM F/IC...
Jungy and I are going to swap cams this Friday, he has the 0014s. After I install the 14s I will see if my problem is fixed, If not, I will have to replace the HG, and check for any other damage...
But according to research, the cams seem to be the problem...
MMFTW
