Old 07-30-2008   #1
Installing seals in n/t TB,
So i attempted to put new seals into a NT TB that i have and i need to get the shafts machined to accept the bigger seals, does anyone know where i can get this done ASAP.
Also i learned why cheap tools are cheap, so they can be destroyed by DSM throttle bodies.
Thanks
Aaron
Old 07-30-2008   #2
twack
It was a auto get over it
twack's Avatar
Re: Installing seals in n/t TB,
dosnt mach v have the small seals too
Old 07-31-2008   #3
What do you mean, have the shafts machined? I installed DSM TB seals in my 75mm Ford TB and all I had to do was bore out the center sections to fit the seals in. It's a funky size drill bit, but I've got it here if you want to borrow it.
Old 07-31-2008   #4
The seals don't fit in the bore they are supposed to fit in, the seals are 10mm.
Old 07-31-2008   #5
I don't think any shaft machining is needed. It's the bore that may need to be drilled. I was able to cram mine in my stock NT TB. But I am not 100% sure that it is leak free. If you find a good way to do it, let me know as I should prolly do the same.
Old 07-31-2008   #6
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Did you destroy the the old seals? Cause you can rebuild them. I dunno if a N/A TB is the same but you can burn the rubber out of the old seal and replace them with o rings. You use the old seal to hold the o rings in. But N/a's probally diffrent.
Old 07-31-2008   #7
NT ones are different. They don't have the metal ring with an O-ring on it.
Old 07-31-2008   #8
I didn't see a metal ring in mine just the o-ring.
Old 07-31-2008   #9
Exactly. Some of the turbo ones use a metal retaining ring that you can reuse with a new o-ring from a parts store. N/T ones don't have that metal ring, they are different then the turbo ones.
Old 08-01-2008   #10
kevbo6204
kevbo6204's Avatar
Drives: #313/1000 '92 Summit White VR4 Galant
I dont know how accurate this info is but it is something...
http://www.dsmtuners.com/forums/1g-n...aft-seals.html
kevbo6204 is offline   Reply With Quote
Old 08-01-2008   #11
Typical tuners thread, questions with no real answers.
Old 08-01-2008   #12
The last post in that thread seems helpful, i am meeting up with kevbo in a few hours hopefully we will figure out if that is true or not.
Old 08-01-2008   #13
I remember reading that thread also. I didn't have any issues with the seal being too long. My issue was more like the holes diameter wasn't wide enough. I had to push real hard, using a socket, to get the seal to go in. And I think some of the rubber may have come off the seal. It was too tight of a fit I think.
Old 08-02-2008   #14
Yeah, well i dropped of the TB to kevbo and he said that he will be able to take care of it for me.
Old 08-02-2008   #15
kevbo6204
kevbo6204's Avatar
Seals are in
Old 08-02-2008   #16
twack
twack's Avatar
if its just super tight couldnt you of put them in the freezer then lube them up and throw them in
Old 08-02-2008   #17
WIll be picking up shortly and letting you all know the results tomorrow hopefully.
Old 08-02-2008   #18
Kevbo would you mind doing another one?
Old 08-02-2008   #19
kevbo6204
kevbo6204's Avatar
I would like to see how turbotalon1g's turns out and then yeah I could take on another i suppose.
Old 08-02-2008   #20
did you bored his out at all or anything?
