Old 09-30-2008   #1
blackrosenova400
blackrosenova400's Avatar
Post your turbo, timing, fuel and fuel ratio!
Lets see what what you guys and gals are all running because I think mine is too high! Ill start off....
EvoIII 16g
19 degrees + 5 base
E85
11.8:1 (Gasoline stoich)
Old 09-30-2008   #2
Re: Post your turbo, timing, fuel and fuel ratio!
Boost and compression ratio would help too.
Also, if your logger says 19 degrees, then that already includes the 5 degrees base.
Old 09-30-2008   #3
9.0 Compression
60-1 @ 27psi
17 degrees
E85
~11.3:1 at WOT
Old 09-30-2008   #4
Spyderturbo007
Spyderturbo007's Avatar
Albatross Overload (Yeti 4) Champion!
Drives: 1997 Eclipse Spyder GS-T
EVO III 16g @ 22psi
AFR ~ 11.8 - 12:1 (I love Meth!)
Timing = 19 degrees at redline
Spyderturbo007 is offline   Reply With Quote
Old 09-30-2008   #5
Evo316G, 22 psi
E85
AFR - 12-12.5
Timing is 15max.
For some reason the car likes it that lean, richer and it knocks and doesn't drive as nice.
Old 09-30-2008   #6
Evo8 (stock compression) w/ IX 16g, 29psi peak
100% methanol or 50/50% methanol, same results, except afr
11.4:1 (100% meth), 11.8:1 (50/50)
Timing is 15-16 way up top but 14 through the main peak power section.
I've been trying to find a way to get the car to run more timing, but it just wants to knock.
Old 09-30-2008   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Evo3 16g - 27psi
E85
AFR - 12.5
Timing - 19
-1990 Mitsubishi Cyborg 4WD-
Old 09-30-2008   #8
dsm9sec
EvoIII 16g
19 degrees + 5 base
E85
Your timing might even be a little low if you're on a stock motor. I use to run 22-24 degrees on a 20g / dual sides mounted up front on 92.
You didn't mention your intercooler either, which also plays a big role in timing.
Old 09-30-2008   #9
My wife's car:
SC61
E85
13 degrees
11.0:1 A/F (It changes though depending on mix or mood)
Old 09-30-2008   #10
So am i running on the dangerous side of being at 12.5?
Old 09-30-2008   #11
blackrosenova400
I have slowboy's front mount. I also didnt know the 5 initial was included in the logger.
So I assume it always assumes 5 degrees no matter where it is on the logger?
Im pushing coolant and was trying to figure out if my cylinder pressure is too high. Maybe its time for a head gasket. I do have a cometic with arp head studs right now.
Old 09-30-2008   #12
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
No your good, I'm running the same A/F but with 19 degrees of timing. Also not to mension when we went to the track I was running a 15.2 afr and didn't know that til the dyno..
Old 09-30-2008   #13
You might be fine. I usually just run them richer to have some amount of safety in case the mix changes or something goes wrong. And I haven't seen much for gains running E85 cars leaner, unlike with race gas, so I don't push it. I have actually had some all-motor E85 cars make more power running about a point A/F richer than we would normally run them on gas.
Old 09-30-2008   #14
blackrosenova400
Well regardless im pushing coolant. Now I got a misfire at idle and cruising. And I see water coming out my tailpipe. Time to pull it!
Old 09-30-2008   #15
blackrosenova400
Well I pulled my spark plugs and found on one of the plugs, the insulator that goes around the center electrode had somehow moved all the way down the electrode, probably causing my idle misfire, by arcing internally or not sparking at all.
Old 10-01-2008   #16
Spyderturbo007
Maybe you want to start your own thread, instead of hijacking this one.
-Nathan
Old 10-01-2008   #17
^Um, noob. He started this thread so that he could figure out if his problem was with the tune he did.
He gave us the results.
Old 10-01-2008   #18
Nightjoker7
Drives: 04 Evo 8 SSL - 95 Eclipse gsx -2011 Chevy Caprice PPV
Send a message via MSN to Nightjoker7
What kind of plugs are you using? I have had the happen to me twice with Autolite plugs, I switched to NGK and its never happen again.
Nightjoker7 is offline   Reply With Quote
Old 10-01-2008   #19
blackrosenova400
Im runnin BPR8ES plugs gappped at .026.
I was told they may be tool cold running e85 and may be causing cylinder freeze which causes detonation. I will find out today as im gonna put in bp7es's in gapped at .024
Old 10-01-2008   #20
We run 8s in my wifes car and almost every Evo 8 runs 8s. .026" gap is on the bigger side for an higher boost E85 car though.
