Old 12-07-2008   #1
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Parts Request
You can PM me the prices. Thanks. Sorry I don't have part #s.
cam seals - 1g head
valve cover gasket 1g
intake manifold gasket - 1g
exhaust manifold gasket - 2g
composite headgasket 1g
thermostat housing gasket - GVR4
Piston rings -1g standard bore
1g oil pump front case - 1g
balance shaft eliminator kit -
MD103722
MD092785
MD098626
MD040597
oil filter housing gasket - 1g
rear main seal - 6 bolt 1g
rear main horseshoe gasket - 1g 6 bolt
oil pickup gasket(in oil pan) - 6 bolt 1g
timing belt 90-94
timing belt tensioner - 1g 6 bolt
'04 Honda Ricer: stock
Old 12-08-2008   #2
Drives: 98 iVTEC
Re: Parts Request
How about my list?
Old 12-09-2008   #3
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: Parts Request
cam seals md372536 $7.80ea
v\c gasket md125939 $27.90
tower seals md125940 $4.54ea x4
half moon seal md050536 $2.48
int gasket md188995 $9.28
exh manifold gasket md181032 $18.06
thermo gasket md145038 $2.56
piston rings md140923 $140.74 need to order
front cover md175762 $196.90
case gasket md149393 $9.54
oil filter bracket gasket md149370 $1.86
rear crank seal md343564 $21.36
rear gasket md183243 $2.32
strainer gasket md183240 $1.64
t belt md326059 $62.60
tensioner md164533 $84.78
balancer bearing md103722 $13.00
shaft md098626 $10.94
balancer bearing md040597 $15.02
cap md092785 $8.82
multi layer head gasket $110.98
sorry I took so long
I've had a lot of body orders to do.
Nick
LUTHER BROOKDALE MAZDA MITSUBISHI
763-503-4695
nick.galbreath@lutherauto.com
http://www.facebook.com/#!/Luther.Auto.Dealerships
http://www.Lutherauto.com
Nick G is offline   Reply With Quote
Old 12-18-2008   #4
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Re: Parts Request
OEM 1993 Talon AWD clutch disk?
