Old 11-24-2008   #1
I need some help with AEM
Ok, installed the wideband and started 'er up. The thing was pig rich, off the meter. So I leaned out about 8-10 boxes all by 10 "points" and the idle jumped from about 750 to 1300, haha. Guess I need to adjust the throttle plate some.
Anyway, my main concern is the coolant temp sensor. It's a GM unit, the AEM read 207 degrees by the time I shut it off. Is there a calibration that needs to be done? I did the wizard thing where you select what sensors you're using, and it was the only GM one there.
Thermostat is a stock temp unit at 195. Any tips? just let it do it's thing and make sure it doesn't go over 210 or 215? Or get a lower temp stat?
Old 11-24-2008   #2
95talonracer
95talonracer's Avatar
Re: I need some help with AEM
DSMlink FTW!
Amsoil Dealer
Old 11-24-2008   #3
I could have used mitsu stuff, but why downgrade from conquest parts to dsm parts?
Old 11-24-2008   #4
b00stcreep21
I hate everyone
b00stcreep21's Avatar
I'd see how hot it actually starts getting, then make sure you don't have any cooling system issues afterwards. You only have a 5v signal going to the temp sensor, right?
Old 11-24-2008   #5
Yeha, I might actually be retarded. I haven't driven the car in 2 years, and I think in that time I've forgotten basic car stuff, its possible it's a 210 degree stat, it's a stock replacement one, so could be, I'll look up what stock is.
Anyway, as for the AEM, it turned red at like 160, so it doesn't know where the threshold is for "too hot". I need to change that for sure.
It's a 5 volt signal sent by the AEM, yeah.
Old 11-24-2008   #6
just checked, OE spec is supposed to be 192 I believe.
Old 11-25-2008   #7
You are probably too lean for the lower cells, I had that problem when I first started with the AEM too. I wasn't able to get the idle down, then I would lean it out and it still wouldn't go down. I actually needed to make it richer.
Old 11-25-2008   #8
Double post.
Old 11-25-2008   #9
I did the opposite, it was super rich, then I leaned it out and it read 10.5 afr. still really rich, I think more than that is unreasonable. I suppose I could be wrong.
Old 11-25-2008   #10
joem
Drives: 1991 Talon awd auto
Most car will run around 205-210. GM's cooling fans will turn on at about 221-227 with the guage at 210 on the dash.
Joe
Old 11-25-2008   #11
Trying leaning it out closer to stoic and make sure your ignition timing is sync'd.
I am available for hire on sunday .
Old 11-25-2008   #12
Joe
Cool, good to know.
I will try that, and thanks for the offer, but I'm broke as a joke right now. I'll let you know what's up once I get my next paycheck.
Old 11-30-2008   #13
ok, so I tried leaning it out at idle, but it didn't want to rev cleanly, it would hiccup and appeard to be going very lean. I richened it up again and it revved clean, but I'm sure it could be leaner. I messed with the accell dTPS table a bit, raised the line up a bunch, and that seemed to help. Are most of the throttle tip-in adjustments done in the main fuel window or auxiliary windows like the dTPS or others?
Old 11-30-2008   #14
Have you tried looking on teh AEM forums for help?
Old 11-30-2008   #15
I don't read forums, forums read me.
Old 12-01-2008   #16
The main fuel maps are used for "base" fuel only. All the modifiers (accel, decel fuel, coolant correction, off idle performance, idle fuel, air temp enrichment) are done in their own respective tables. I've seen many people that try to use "unused" portions of the map for accel fuel. Then they wonder why the car runs like shit in different gears and under different load conditions (like large hills that they normally don't encounter). The AEM manual has a decent explanation of what each table does and how to start tweaking them.
Old 12-01-2008   #17
Thank you, that was what I was looking for.
Old 12-01-2008   #18
Shotgun!
Totenritt
Shotgun!'s Avatar
Joe
GMs use reverse cooling and will run much hotter because of it. There is no comparison to turbo mitsus.
Old 12-01-2008   #19
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
My MS2 uses a GM cooling sensor and it is usually in the 200
I wouldn't worry about it until it goes up to 220 or something like that. My stock coolent temp sensor for the dash is still plugged in and it reads normal at 200
How I tuned my idle is:
Shut off all enrichments and things that would modify the Base fuel map
*just to add, the reason why it is bucking is probably because of your accel fuel enrichment isn't high or low enough but forget this right now.
Turn up your idle screw a couple of turns (this will prevent it from dying out at idle and warms up the car pretty fast)
warmed up your car so it is at operating temps.
Then tuned the base fuel map idle by ear
Reason of not using your WB is depending on your cam, you may need to run richer then 14.7
I know I had to change my base tune when I installed my 272 I think mine is at 14.0-13.5 and runs just fine like that
*Also at Idle I have the computer look at the throttle Position because with the bigger cam, I loose vacuum at idle which throws off my MAP sensor.
*My accel enrichment is a blend of MAP reading and TPS reading but again all of that is shut off when tuning just the base fuel map
Next you have to dial in your base map which means no hard pulls. Just running the car up the RPM little by little to dial in the Fuel map. This is where you would use the O2 sensor. I don't know what AEM has but MS2 has megalog which is a program that will help you dial in the base fuel map. Really helpful
To make it short. Once you have the fuel map set, you can leave it and never have to change it again unless you mod the car with something else.
After the fuel map is dialed in, you can change your enrichments
Tuning becomes addicting once you figure out how to. There is a steep learning curve however
What are you using for spark output?
Old 12-01-2008   #20
dsm coil pack. I want to learn how to tune, but I might need some lessons from a pro before I'd feel confident.
