Old 04-26-2009   #1
Brent Rau
Frightens Puppies with a Flick of the Ankle
Osofast 1300 hp motor
This is one of my used race motors that ran 6.90s@198 mph. I have freshened it up and its ready to go!! This is not a streetable combination! Race only. Alcohol or gas.
This motor will support 1300 H.P.
Steal this $15,000.00 motor for:
$6,000.00 or BO
Block:
6 bolt
Kevlar timing belt
Balance shaft eliminator kit, pulleys, belt tensioner, front cover, oil sending unit
New oil pump
belt tensioner
O ringed
Solid filled with hardblok (NO WATER) Water flows in head only
line honed
deck cnc surfaced
JE high compression pistons
Aluminum MGP Rods
Balanced/polished/clearanced Crank
Calico coated race bearings
Head:
CNC ported
Custom cam gears
valve cover
MLS head gasket
Crane cams
New rockers
New custom lifters
A1 L19 head studs,nuts and washers
CNC decked
Billet cooling system flow adapter
Head drilled and taped for breather line fitting
Bronze guides
Ferrea 1 mm over Stainless intake valves
Ferrea 1 mm over Inconel exhuast valves
Ferea high temp valve seals
Osofast racing valve job
Ferrea Bee hive high pressure springs, locks and locaters
Titanuim retainers
Exhuast studs all helicoiled for strength
No intake manifold, No exhaust manifold, No turbo, No oil pan, No oil pick up tube.
Brent Rau is offline   Reply With Quote
Old 04-26-2009   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: Osofast 1300 hp motor
Oh my...I'll take two..haha
