Old 05-14-2009   #1
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
Control Arm
Would a 2g GSX control arm fit a 2g GS? I found some cheap ones for a GSX but I don't want to buy them if they will not work for my car.
Old 05-14-2009   #2
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Control Arm
Yes, they are the same.
Old 05-14-2009   #3
Hoffer00
Cantankerous Tank Champion! Fight Man Champion! Go Johnny Go Champion!
Re: Control Arm
See how your question was answered. I would feel like i'm hijacking your thread.
How would you go about getting the control arm in to the steering knuckle. If you are putting it in yourself. When i try to tighten the nut it just spins. What do I have to do to get it the rest of the way on.
Old 05-14-2009   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Control Arm
You could try putting a jack under it to press it tight into the knuckle so it doesn't spin.
Or the ghetto way is to hold it with a vicegrips (under the knuckle) while you tighten it.
Old 05-14-2009   #5
Hoffer00
Re: Control Arm
when i tried the jack. and the c clamp gets in the way when I would try to tighten it. i have heard of heating it. is that something i should stay away from.
Old 05-14-2009   #6
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Re: Control Arm
thanks 1quick4 for the anwser and hoffer don't worry about hijacking.
Old 05-14-2009   #7
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: Control Arm
Is it for the rear? I probably have an extra control arm from a gst? Pretty sure it's the same.
Old 05-14-2009   #8
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Re: Control Arm
Front :-/
Old 05-15-2009   #9
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Control Arm
Originally Posted by Ihearrtdsm View Post
Front :-/
upper or lower? if upper, just put the wheel on & lower the car till it's got some weight on it ( you can lower the car all the way if you really want )then start the nut & tighten it till it is tight, raise the car, remove the wheel again & torque the nut down.
Old 05-15-2009   #10
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Control Arm
Considering it's a 2G I'm going to have to say it is the lower he is talking about. All 2G lowers are garbage.
Old 05-15-2009   #11
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Control Arm
I had the same spinning problem with the ball joint on the upper control arm on mine. Just replaced the lower control arms on mine too.
Old 05-18-2009   #12
Hoffer00
Re: Control Arm
it is the lower it is a 99. I have tried vehical weight. jacking up under it. c clamping it. The only thing left to try is the ghetto vise grip. unless you guys offer some better ideas. Thank you to everyone that has given feedback, it is always a great help.
Old 05-18-2009   #13
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Control Arm
hmm Try a new arm if all else fails... 30-60bucks depending on kind and where ya get it.. O'Reily usually has some in stock.. or maybe someone can come give ya a hand... where in MPLS are ya
Old 05-18-2009   #14
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Re: Control Arm
Hoffer if you get it to work post up what you did, I will be doing lower in the future.
Old 05-18-2009   #15
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Control Arm
I did my lower with new ones & had no problems other than the CV in the way.. but I did the CV's at the same time. just start prepping by spraying some PB on the bolts & nuts. You'll be glad ya did.. & remember to reassemble with some anti-seize.
Old 05-20-2009   #16
Hoffer00
Re: Control Arm
That one was new from brookdale mitsu. I'm in Brooklyn Park by 694 and 169
