Old 07-13-2009   #1
Cyclic thumping sound from rear wheel
This is on my girlfriend's 2001 Escort zx2, when going around right corners somewhat fast the rear end seems to have this clunk/thump sound which sounds to be directly related to how fast the wheels are spinning. Not on left corners though, so I'm thinking it's the rear driver's side wheel area since that would be the outer wheel getting more force on a right turn. It doesn't make any sounds under slow turns, but gets louder the harder you turn.
Any ideas what it could be? It's got 95k miles on it, all original parts.
Old 07-13-2009   #2
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Cyclic thumping sound from rear wheel
I'm not familiar with these cars, but... have you checked the rear sway bar links/bushings? Maybe the shift of weight when turning it causing it to make that noise. Or could it be a wheel bearing - if I'm understanding you right, it will clunk over and over with the speed of the tire.
Old 07-13-2009   #3
Rhythmic sound related to speed and turning = wheel bearing
Old 07-13-2009   #4
A wheel bearing would cause a whine typically, not a thump. I would say if the car have ball joints in the rear, it could be that.
Old 07-13-2009   #5
Having the sound increase and decrease based on turning would have nothing to do with ball joints, specifically if it's also related to speed.
Old 07-13-2009   #6
Sure it would, the tighter you turn the clunkier it could get.
It does sound like it could be a wheel bearing though the more that I think about it.
Old 07-13-2009   #7
I'll do some more spirited turning today at different speeds to verify, but I'm pretty sure the frequency is speed dependent. Loudness is force dependent.
I was thinking wheel bearing at first, but was hoping for another possibility.
Old 07-14-2009   #8
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I'm voting wheel bearing. Ball joints and sway bar links/etc don't typically have a cyclic thump that relates to wheel speed.
Style's automotive engineer
Old 07-14-2009   #9
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
loose lug nut...maybe
Old 07-14-2009   #10
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Check your lugnuts (ask Halon about that one )
Old 07-14-2009   #11
I would say to check lug nut tightness, and if that doesn't fix it, it's most likely a wheel bearing.
Old 07-17-2009   #12
Well I don't think I'll ever know for sure what it was. Emily took the car in for an oil change because I didn't have time before we left today, and they rotated the tires. They also said she needed new outer tie rod ends (I could shake the wheel back and forth a lot, it was bad), so we got some at oreilly's for 1/3 the goodyear cost and had that done too. Well now the problem seems to be gone, so who knows.
I know there was a vibration issue in the front end which I thought was a tire out of balance, but it was probably just the wheels shaking because of the bad tie rod ends.
