Old 11-05-2009   #1
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
cleaning?
i recently spun a rod bearing in my 7 bolt and i was just wondering do i need to clean any thing out like the turbo drain tube.... i am going to reuse the turbo and may be the head but im getting a different block or motor
96GST16g is offline   Reply With Quote
Old 11-08-2009   #2
96GST16g
livin the dream
96GST16g's Avatar
Re: cleaning?
so no body knows? thought ppls would
Old 11-08-2009   #3
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
Re: cleaning?
Yes you should clean everything. This recently happened to me as well and I brought my head to MAP and they pulled all the plugs and washed it all. Plus things like the oil drain need to be cleaned because you wouldnt want to just reintroduce metal back into the oiling system again and have it all happen again right away.
Short answer....Clean everything.
Mwolf83 is offline   Reply With Quote
Old 11-08-2009   #4
Re: cleaning?
3M brake cleaner works very well for cleaning stuff like oil lines.
Old 11-08-2009   #5
Re: cleaning?
+1 on the 3M brake cleaner (specifically that one) and there's mixed reviews on whether or not you should replace your oil cooler or just clean it.
Old 11-08-2009   #6
spinz4
spinz4's Avatar
Send a message via AIM to spinz4
Re: cleaning?
Ya it can be pretty difficult to know whether or not you've cleaned the oil cooler good enough.
spinz4 is offline   Reply With Quote
Old 11-09-2009   #7
Re: cleaning?
Replace the oil cooler, there is no way to get all the metal bits out.
