Old 02-17-2010   #1
2zzgtte
The Russian Stub
2zzgtte's Avatar
Drives: 2001 Celica, 2005 Evo
e85 FAQ?
Anyone know where I can find a FAQ on E85 conversion for an Evo? I did a search and I don't wanna ask redundant question
I found one on Evolutionm.net but that was for an Evo X. Anyone know where I can find information for an Evo VIII?
2zzgtte is offline   Reply With Quote
Old 02-17-2010   #2
mike55112
mike55112's Avatar
Drives: 04 evo
Re: e85 FAQ?
Have you joined evomn.net yet? If not you really should. Thats where you will get alot more info on evo stuff from all the local evo owners.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-17-2010   #3
Re: e85 FAQ?
All you need is more fuel. Bigger injectors and a walbro 255HP for stock to medium sized turbos. Huge injectors and more fuel pump for big turbos.
Old 02-17-2010   #4
v8klla
v8klla's Avatar
Re: e85 FAQ?
It's pretty simple actually: Walbro 255, larger injectors, and a reflash
Edit: Whoa triple post! lol
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-17-2010   #5
jrohner
jrohner's Avatar
Re: e85 FAQ?
And for tuning pretty much ignore your knock sensor because you can usually add way too much timing before seeing knock. Knock just isn't very useful for tuning E85 unlike pump gas; yes you still log it just in case of an issue. You need to either dyno or log and estimate hp (road dyno) to get your timing just right.
To get the fueling right, I just divide the injector comp by 1.4 to change it to E85 and it works out pretty well.
Old 02-17-2010   #6
2zzgtte
The Russian Stub
2zzgtte's Avatar
Re: e85 FAQ?
isnt e85 corrosive?
if so, the walbro is can withstand the corrosives?
What would larger injectors be considered? 1000cc?
e85 screw with a wideband? aem ugeo?
Old 02-17-2010   #7
Re: e85 FAQ?
E85 is not corrosive.
Old 02-17-2010   #8
Re: e85 FAQ?
1000s would good for stock turbos. E85 is not very corrosive, methanol is very corrosive. I haven't seen any Walbro failures from E85. E85 is easy on O2 sensors, unlike leaded race gas.
Old 02-17-2010   #9
mike55112
mike55112's Avatar
Drives: 04 evo
Re: e85 FAQ?
I have 1000cc's and I have made 458 wheel at RS motors at 90% IDC. I have been running e85 for about 20k and have no problems with my fuel pump or and fuel lines.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-17-2010   #10
2zzgtte
The Russian Stub
2zzgtte's Avatar
Re: e85 FAQ?
Oh sweet! Alright so lets say i change my gas, and injectors, Do i need to do something before I limp it to Shane for a tune?
Or is there a way i can tune it a little before i bring it there just so it is safe when driving for about 20 miles?
Old 02-17-2010   #11
mike55112
mike55112's Avatar
Drives: 04 evo
Re: e85 FAQ?
Just drive to db with no under a 1/4, bring some e85 in a container and have shane put the injectors in.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 02-17-2010   #12
Re: e85 FAQ?
If you have a reflash cable, I can send you a basemap to get you up and running.
Old 02-17-2010   #13
Re: e85 FAQ?
This. Then make sure you run a few tanks through the car before the tune and you'll be good to go
I say get PTE 1000's if you plan on staying on the stock turbo, or FIC1250's if you ever plan on upgrading. There are quite a few people running E85 for years on end around here with great results. Just stay on top of the tune, scout out E85 locations near you, and consider the change in seasons, you'll be good to go.
Old 02-17-2010   #14
2zzgtte
The Russian Stub
2zzgtte's Avatar
Re: e85 FAQ?
Well, I plan on upgrading to Evo 9 turbo sooner or later. When I get back from Florida, I am going to do timing belt and I have GSC S1 cams so maybe I should get a reflash cable, throw some new injectors in and get it decent before I bring it there?
PTE injectors a good injector? I noticed in the "modding your evo 100$ at a time" thread, you guys mentioned FIC being a good fit?
Old 02-17-2010   #15
Re: e85 FAQ?
With the stock turbo why not run a bit smaller like the 850's?
I personally like FIC injectors; they're reasonably priced and have never given me any problems.
Old 02-17-2010   #16
Re: e85 FAQ?
850s running E85 on my dyno will be maxed around 340awhp.
Most of the E85 cars I tune either have the PTE 1000s or the FIC 1250s.
Old 02-17-2010   #17
Re: e85 FAQ?
Ahh ok, looking at my IDC's on pump gas I would have figured they had more in them.
Old 02-17-2010   #18
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Re: e85 FAQ?
Im on pte 1000's. But might be sellin them because of my bigger turbo.
Last edited by Kracka; 02-17-2010 at 01:23 PM.. Reason: please use the classifieds for selling parts
Old 02-17-2010   #19
2zzgtte
The Russian Stub
2zzgtte's Avatar
Re: e85 FAQ?
Does e85 need a lot of tuning and screwing with? I think I might pick up a tactrix cable later tonight.
What is this Tactrix OpenPort 2.0? Do I need that?
http://www.tactrix.com/index.php?pag...mart&Itemid=53
Old 02-17-2010   #20
mlomker
*Resting In Peace*
mlomker's Avatar
Re: e85 FAQ?
That's the interface between your laptop and the ECU. It works out of the box with the Evo X and you plug in the Mitsu adapter for any of the older Evos. If you buy the kit then it comes with everything, including Subie adapters.
http://tunertools.com/proddetail.asp?prod=OpenPort2Ful
