Old 05-12-2010   #1
b00sted_spyder
Vacuum line, where do they route to?
I'm getting closer to getting everything ready. How do I route the vacuum lines to the MBC, BOV, wastegate, fpr, GM MAP sensor, and throttle body? Anything else I'm missing?
Old 05-12-2010   #2
viridionplague
Re: Vacuum line, where do they route to?
throttle body dosent need any,
MBC line should come from a source as close to the turbo as possible, to the MBC, then to the wastegate.
FPR needs a line coming from the intake manifold.
BOV also needs a line from the intake manifold. preferably NOT from a T splitter connected to the fpr.
GM MAP SENSOR can be should be located either in the upper intercooler pipe or intake manifold if your just using it for a boost reference, not 100% sure where you need it for speed density.
also there should be a big line on the back of the intake manifold that goes to your brake booster.
EDIT: there is also a line that runs from the intake manifold to the valve cover, and another line that runs from the valve cover to the intake pipe.
Old 05-12-2010   #3
Vfaq.com - all questions should be checked here first.
