Old 08-10-2010   #1
1G_DSM
1G_DSM's Avatar
Drives: 1994 Eagle Talon TSI AWD Auto
Test drove my first Evo today
Alright I test drove my very first Evo today. Holy crap I felt like a total noob driving it, let me explain...
I've been driving my '91 Eagle Talon TSI for like 5 years or so. I'm used to the way the clutch feels and how it engages (ACT26000, kind of a hard pedal feel, engages almost right away when you let it go a bit). I've never really driven any other manual car.
When I drove this Evo, I had a hard time feeling the clutch. Clutch felt really soft compared to the one on my DSM and you really had to let go of the pedal before it engages, or at least in my opinion it does. Man that was embarrassing, luckily I didn't stall it. The owner must have been like, are you sure you know how to drive a stick?, lol.
Man now I'm scared to go look at other cars now. I feel like I have to re-learn how to drive a manual car because I'm only used to driving mine.
1G_DSM is offline   Reply With Quote
Old 08-10-2010   #2
Re: Test drove my first Evo today
Every car is different, especially with aftermarket clutches. Takes a few starts to figure out the engagement point and you can't be asleep at the wheel.
Old 08-10-2010   #3
1G_DSM
1G_DSM's Avatar
So this is normal then? because if it's not I felt like a total noob. Sounded like I was trying to rev his engine and I wasn't. I couldn't find out when the clutch engages. I felt stupid, that's all.
Old 08-10-2010   #4
Once you get used to it a light clutch pedal is very nice since you can be so precise in your action with it. Go from an Evo with a stock clutch into a DSM with a 2600 and you'll realize how silly such a heavy pedal is.
Old 08-10-2010   #5
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
lol. yeah, i remember when i drove my cousin's talon with the 2600, i thought i was pushing against a brick wall. haha. right after that i drove a honda with the lightest pedal ever. :P
ლ(ಠ益ಠლ)
Old 08-10-2010   #6
Tachyon
Tachyon's Avatar
Drives: Icarus
How does an evo petal feel with a 2600/2900 or equivalent? I was amazed when I drove a 2g with the same clutch as my 1g (2900 6 puck) and it took roughly half the petal effort to press. Is an evo even less than a 2g?
-Sebastian Vettel
Old 08-10-2010   #7
I've never driven a 2G 2600 (that I can clearly remember), but the Evo HDSS (2900?) is far lighter than the 1G 2600.
Old 08-10-2010   #8
You don't need to put a 2600 or 2900 in an Evo. Most guys run the lowly HD which is called a 2100 on the DSMs with a sprung 6-puck and that setup holds 700+whp, which is more than the Exedy twin disc for the Evo will handle.
Old 08-10-2010   #9
95talonracer
95talonracer's Avatar
come test drive mine, it is for sale
Amsoil Dealer
Old 08-10-2010   #10
1G_DSM
1G_DSM's Avatar
It's the silver one right? I think we talked already. I will keep you in mind, but I'm kind of picky when it comes to what I want. I only checked out this one Evo so far but they are hard to find.
Old 08-10-2010   #11
awd-drifter
'2of9'
when the galant sells, i will give you a call
ლ(ಠ益ಠლ)
Old 08-10-2010   #12
cmspaz
Walls need hugs too
cmspaz's Avatar
My 2G pedal was super light with the 2600, but I also hadn't removed the restrictor pill.
My Evo, which I assume has the pill removed already based on how it feels, is much heavier with what I've been told is a stock clutch.
So I dunno, I'm seeing the reverse.
Originally Posted by Trogdor
Old 08-10-2010   #13
Tachyon
Tachyon's Avatar
Drives: Icarus
How does that work? does the clutch just have that much more surface area or are the rating systems different between the DSM and Evo PP? (sorry I have limited experience with the Evo)
-Sebastian Vettel
Old 08-11-2010   #14
curt_gendron
curt_gendron's Avatar
As mentioned already, every car will have a different clutch feel. You could drive five different Evos and every one of them will feel a little different. Between adjustments in engagement points, aftermarket clutches and wear and tear, every car is a little unique in its clutch feel.
Just get out there and drive a few more sticks and you'll know what we mean.
have fun,
Curt
Minnesota 3/S
Old 08-11-2010   #15
If anything, the clutch pill removal should yield a lighter feeling clutch since you're no longer pressing against the pill/spring. Should be a negligible change though, my guess is any difference people feel is due to fresh fluid and bleeding the system.
Old 08-11-2010   #16
My guess is the pull style clutch that Evo's use.
