Old 03-19-2011   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
NLTS on v2.5
Can anyone back up what Ive read? From the looks of it it will work. What I need to do is splice the red and black wires at the cruise switch and hook the wire up to pin 91 on the ecu. I did research just want to confirm. Or someone find a better diagram of what to do and post it.
Thanks in advance.
Old 03-19-2011   #2
Re: NLTS on v2.5
I just tried to search for you and I couldn't find anything. I can't believe I didn't find anything on teh forums.
Old 03-19-2011   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: NLTS on v2.5
Aaron this is what I found but its v3
http://www.dsmtuners.com/forums/arti...all-setup.html
Wouldnt it be the same for v2.5. I guess thats my question.
Old 03-19-2011   #4
Re: NLTS on v2.5
Oh, yeah I'm pretty sure nothing changed for the wiring between the versions.
Plus it won't fuck anything if it isn't, the only side effect from this is that you lose the ability to stop cruise control by stepping on teh clutch I believe.
Do it up, let me know how it goes.
Old 03-19-2011   #5
95talonracer
95talonracer's Avatar
Re: NLTS on v2.5
You splice the clutch switch wire down by the clutch pedal.
Amsoil Dealer
Old 03-19-2011   #6
Re: NLTS on v2.5
http://www.ecmtuning.com/downloads/d...structions.pdf
I used that how to when wiring mine up. Worked on my v2 and v3.
Old 03-19-2011   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: NLTS on v2.5
Thanks guys I'll do this tomorrow as well as install my wideband.
Old 03-21-2011   #8
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: NLTS on v2.5
Did I give you the DSMLink packaging? If not, I have the supplied NLTS clutch wire harness Link gave me years ago in the garage.
