Old 06-11-2011   #1
93gtpeater
Drives: cbr 1000rr repsol
Any tips when installing cams on a 1g
I would like to install my new cams today when I get off. I want to do it right the firs 2g time and not mess up anything when I put them in. so does anybody have any tips on what to do and what not to do?
Old 06-11-2011   #2
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Any tips when installing cams on a 1g
Do one cam at a time, use antisieze on the threaded rod to remove tension. I just did cams yesterday on my evo and it was a lot easier than I expected for my first time. Just take your time and torque everything to spec
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-11-2011   #3
Remove tension a bit zip tie/adhere belt to gears, pull off gears swap cams, put gears back on an voila new cams installed in under an hour and timing is dead on.
Old 06-11-2011   #4
93gtpeater
Thanks guys. But iam putting cams in now cause it needs a new timing belt. figure if iam putting a belt on mine as while put cams in.
Old 06-11-2011   #5
blackawdtsi
Drives: 2G DSM
Make sure arrows are where they need to be, dowel pins are UP and tighten your new bolts if you are putting in adjustable cam gears.
Old 06-11-2011   #6
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Don't forget to bleed your hydraulic lifters or you "could" bend valves
Old 06-11-2011   #7
93gtpeater
I didnt know you had to bleed the lifters
Old 06-13-2011   #8
Swanny
Swanny's Avatar
Drives: 2G Talon
You dont
Swanny is offline   Reply With Quote
Old 07-05-2011   #9
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Cam caps torque 17ft lbs to add in for quick reference. Lol I didn't see it was 3 weeks ago.
