Old 09-27-2011   #1
mondale
Drives: 1g dsm
Want to borrow an Ecmlink MAF or SD Cable!
I am trying to pinpoint a fault that is causing my AEM 5 Bar to go berserk. I could really use a different ECMlink MAF cable that has been switched to SD pigtails, or an actual ECMlink Speed Density cable with pigtails. I would only need it for a few mins to take a log. I can pick up the cable from you if you are in the metro area, or you could come with while I use it quick. I will not steal your cable. Help me get this thing on the dyno before its too late in the season!
Wade
320-267-0149
mondale is offline   Reply With Quote
Old 09-27-2011   #2
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Want to borrow an Ecmlink MAF or SD Cable!
If I still had that 1g I would let you use my cable. Good luck man
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 09-28-2011   #3
Hey, FYI to erry body in the club.
I personally know Wade, he won't steal your shit. He doesn't post much, but he is a stand-up guy in real life.
So, if you have a fancy smancy ECMLink cable, please help a fellow DSMer out!!
Old 09-28-2011   #4
You can borrow mine. It is currently in Oakdale and I should be around all night after 4:30ish if you wanted to come borrow it tonight. Otherwise I could bring it to work in St. Paul and you could pick it up from me there.
Old 09-28-2011   #5
mondale
Drives: 1g dsm
Awesome!! I could meet you up anytime after 2 tomorrow. I will pm you my info.
Wade
8.59 @ 158
Old 09-29-2011   #6
If u are looking for a link cable that goes in the car I have one u can try or I have the 1g mas to sd setup cable if u want to try.
Good luck
Old 09-29-2011   #7
mondale
Drives: 1g dsm
Miscommunication between me and C3l1ca about which cable i need. Thank you anyways brad for going out of your way to help out a random!
I am looking for the cable that is in the engine bay that physically connects your maf/sd sensors to the engine bay factory connector.
Aaron is your maf cable already wired up for SD use? I wouldn't want to hack up someones breakout points on their cable if they aren't already wired for speed density use.
8.59 @ 158
Old 09-30-2011   #8
its the premade cable from DSMlink, it has 1G mas/maf on one end and the other 2 ends is for GM IAT and GM style MAP sensor, there is a pic in my FS thread. should be home by 530-6
