Old 02-25-2012   #1
Rebuilding a NT throttle body
Can anyone point me in a good direction?
Right now I have bad leaks around the shaft seals, but I'm finding any replacement seals, I think that I can use turbo ones but I have to have this TB shaft bored out or something.
I could of swore I did this a few years ago.
Old 02-25-2012   #2
Re: Rebuilding a NT throttle body
Put in DSM turbo shaft seals backwards. They won't go in all the way, but I don't know of anyone who has the correct ones.
Old 02-25-2012   #3
Ok, I think I had someone who used to be a member on here enlarge the bore where the TB shaft is last time so that they would seat better.
I'll try that though, they leak terribly bad on my car.
Old 02-25-2012   #4
I found this post on tuners:
Tsunari:
"For future reference, you can have the body of the NT TB where the seal goes bored .040" deeper and the turbo TB shaft seals should fit. For some reason, that recess on the NT TB is only .100" deep as compared to .140" deep on the turbo TB.
Or perhaps dig around for a seal similar to the turbo shaft seal but something not as tall
****EDIT****
1G Turbo 10mm x 14mm x 3mm
1G NT 10mm x 14mm x 2mm --- If you can't find a seal like this, bore the recess 1mm deeper (a total of 3.5 - 3.6mm) and use the Turbo seals
So i guess next step is too find someone who can bore out the part where the seals sit for me, and I'm picking up some mil.spec turbo TB seals.
Old 02-25-2012   #5
I have them instock, if you need them.
Old 02-26-2012   #6
Just bore them out and use the seals, I did that on a 75mm Ford style TB a few years ago, worked great. It takes a goofy size drill bit, I have it laying around somewhere.
Old 05-18-2012   #7
^any chance you can find that drill bit?
Old 05-18-2012   #8
Yep, I have it on my workbench, or just bring your TB over and we'll throw it on my drill press.
Old 05-18-2012   #9
nice i'll give u txt tomorrow if that works?
Old 05-18-2012   #10
Oh, I have one I would like to do this to as well!
Old 05-18-2012   #11
Arrange with Brown and we'll set up a time. I'll be getting the boat ready tomorrow at home.
Old 05-18-2012   #12
Sweet, this is my last Sat-Sun off work for probably the rest of the summer. I wanna get some shit done
Old 05-18-2012   #13
Sounds good, i need to take it apart once i get home tomorrow and I'll use it as my break from wrenching.
Old 05-18-2012   #14
Shoot me a text.
