Old 08-11-2013   #1
punxnotdead185
Drives: 95 AWD Mirage Coupe with AIDS
Evo 8 9 TD06SL2 20g turbo, fresh rebuild, ported
I have a 20g I got for cheap and had rebuilt. Its in good condition with a ported 10.5cm Evo 9 turbine housing, TD06SL2 turbine wheel, should be good for almost 500awhp depending on how hard you want to run it. Asking $400 but open to offers, hoping for a quick sale. Text 218-499-9151 if interested.
ID:	13892   Click image for larger version
ID:	13893   Click image for larger version
punxnotdead185 is offline   Reply With Quote
Old 08-11-2013   #2
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Evo 8 9 TD06SL2 20g turbo, fresh rebuild, ported
small evo 8 compressor housing, 500whp?...
2006 WW IX RS 396/404 - SOLD
Old 08-12-2013   #3
punxnotdead185
Not sure, idk if the Evo 8 ones are that restrictive, everything I could find on evolutionm says that although the 9 cover is physically bigger it doesn't actually flow more because the air channel inside is the same volume just the diffuser is bigger, which is the reason for the bigger back plate. This does help build boost slightly faster but an actual gain in power would be minimal and building boost a couple hundred rpms faster was the sole reason Mitsubishi changed the design. 9 turbos have a bigger turbine housing and a bigger compressor wheel, 49.2mm vs 48mm, and that's the main reason they make more power than 8 turbos. That's just what I read on evolutionm, the more important part that's better on the 9 turbo is the turbine housing which this one has.
Old 08-16-2013   #4
punxnotdead185
Buy me!!!
